Driver Door Issues...Window & Lock... 00 CR-V
2000 Honda CR-V EX 5spd 195xxx miles
Ever since I bought my CR-V, the driver window hasn't worked. If I hit the window switch for it, I can hear and feel the motor pop/click. Is the motor bad? I've never done any work on window systems...
Also, my driver door doesn't lock. Not with the power switch, by hand, or by the key fob. Is this related to the window issue? Or is it a separate issue? I had to clear a CEL for my MAP a while back, and the code reader had a code reading saying the driver door lock system was receiving both lock and unlock signals simultaneously...
Thanks for any help/info!
Re: Driver Door Issues...Window & Lock... 00 CR-V
Most likely a broken wire or two in the harness that goes through the door. Seems to be a common issue, I have had to fix a few of these now and it is getting annoying.
