Honda CR-V & Element 2WD & 4WD Element & CR-V
2008 CR-V 2.4 NO-Start
Old 12-20-2021, 02:03 PM
Donald Sprague's Avatar
Default 2008 CR-V 2.4 NO-Start
Under hood fuses all O.K. !
Lights go on !
Radio goes on !
Turn key to "START" and the warning lights go off on the dash but "no noise from the starter".
The car has factory installed alarm...could it be the "immobilizer".
The alarm system "goes on /off".
The "doors" lock/unlock with keys and remotely.
Do I have to go to the "Dealer" to have them "reprogram" my "key".??
Old 12-20-2021, 04:13 PM
Acuraforever's Avatar
Default Re: 2008 CR-V 2.4 NO-Start
Lights go on !
Radio goes on !
Sounds like your starter is dead
Old 12-20-2021, 11:23 PM
ajchien's Avatar
If it was your immobilizer, the green immobilizer light will be flashing. Plus, the immobilizer will cause a “crank, no start” since it cuts the fuel supply. It sounds like you should go down the “no crank, no start” pathway.
gus@organizitco
12-23-2019 05:27 PM
candyman206
Audio / Security / Video
09-15-2007 07:57 PM
rokwilder1
33
06-28-2006 10:49 AM
sooo_slow
03-19-2005 05:29 AM
GSRacer1
11-22-2003 11:50 PM
Quick Reply: 2008 CR-V 2.4 NO-Start
