96 Honda CRV Won't start unless I press the Gas Pedal
Just bought a 96 crv, when I turn the key it starts then dies unless I press the gas pedal. So far I've changed the spark plugs, fuel filter, and the battery and it still doesn't work. Any help would be appreciated.
Re: 96 Honda CRV Won't start unless I press the Gas Pedal
start by checking for codes. regardless of an illuminated MIL. if none present, check fuel pressure. if good, check ignition using an HEI tester. if both check out good, service your fitv
Aaron Weise
07-09-2018 09:19 AM
