2000 crv transmission issues?
So i took the case off to reseal it on the transmssion b20b for a 2000 crv i tried to put it back on together & now i have no neutral can someone please send me pics or some advice its a 5 speed manual transmission for b20b im also having issues with putting the gear shifter after you install the case its what links the shifter cables to the trans i could use a diagaram any help would be appreciated!?!?
Re: 2000 crv transmission issues?
Did you seat the snap ring properly? A lot of times you need to flip the transmission upside down (bell facing up) and gently tap the transmission against the floor/bench to seat the snap ring.
-Amp
-Amp
no the snap ring is there but i didn't snap into back into the groove yet my transmission is cable shift idk is that makes a difference i had to take out this shifter piece out so i can remove the case i put the case back on i put this piece back in & theres no neutral theres 2 cables on this trans so if i take one of them off i can shift 1 through 5th gear also had reverse but couldnt figure out neutral it was almost like this piece was stuck i didnt want to push it too hard and break anything ?
You need to snap that ring back into place. That's part of the shaft alignment. You're probably binding because the shaft isn't seated properly.
-Amp
-Amp
It honestly sounds like you didn't put the forks back in correctly.
-Amp
HondaDadx2
12-05-2015 01:15 PM
