*Official H/T OFFROAD/LIFTED CR-V thread!*
#2228
Re: *Official H/T OFFROAD/LIFTED CR-V thread!*
Finally got all terrains ! General Grabber AT2 215/75/15. I got lucky because someone special ordered them and flaked on the shop so l got em for buy 3 get 1 free with an alignment as well.
#2231
had mine out for a cruise last weekend. Had to swing by and check out the new CRV's. Actually like them quite a bit.
#2233
-Intl Steve Krew
Ordered an OEM roof rack.
Debating on lift spacers for the rear, or a front bull bar, or the OEM fender flare kit...
#2235
Fish Twig
They had fender flares for the crv's?
Yes to the roof rack and the step bars and the rear table and the fold out tent and the offroad rally type fog lights and the bull bar and the...etc etc...etc...etc...
#2237
When it comes to roof racks, how is the max amount of pounds measured? The oem racks are rated what? 75lbs? So does that mean each rack can handle up to 75lbs which is 150 total? Only being able to throw 75lbs up there seems like a damn rip...
I'll see other racks on eBay and they'll be rated at 150lbs.
#2238
-Intl Steve Krew
If you want more weight up top it'd be best to go with an aftermarket Yakima or Thule type crossbar set up.
The cross bars are literally held on by only 3 or 4 cap bolts in each foot, they'll rip out with too much weight.
On top of that, one must always mind the center of gravity. This is why it's retarded to throw a 30lb spare, full ice chest, and all your recovery gear on the highest point of your vehicle where it puts the greatest rollover stress on the vehicle.
I mostly bought the crossbars for looks, and if I do throw anything more than a rooftop box full of bulky stuff (think big sleeping bags and stuff that'll take up space but not have much mass) up there I'll upgrade it to an aftermarket set up.
The most I'll put up there would be a light weight 2 person kayak.
#2239
Come get this and spread the joy.
2007 Honda CR-V service manual (PDF, 80.2 mb) - has full links and bookmarks.
http://www.hondahookup.com/forums/sh...55#post2325055
#2240
-Intl Steve Krew
Installed the eBay OEM style crossbars today. Not super satisfied with them (had to elongate the slotted holes for alignment of the foot pads) but for $67 I can't really complain.
Also washed it lol.
Also washed it lol.
#2241
-Intl Steve Krew
No structural problems. They're aluminum with an oval cross section. The channel has a rubber strip for cover. I've hauled duffle bags and my kids climb up there without problems. The end caps mounted well but have cheap plastic covers that can fall off. They're only cosmetic.
I'm thinking I either need to add either a fairing, or a rack to buffer the wind noise.
I was also thinking of maybe a DIY solution to use some pipe insulation and zip ties to give disrupt the airflow a bit and see if that helps.
#2242
Took me almost 2 weeks to realize i had to go back to to the shop to tell them i wanted white letters out instead lol so they did it for 45 bucks
#2243
I want new Honda CRV Touring, this is the best AWD SUV in the world!
#2245
Final thoughts before I pull the trigger. Cragar 15x7 -0mm Offset, 6mm Spacers and the BF Goodrich 215/75R15 WITHOUT lifting the V. Will it rub a little, a lot, will it work or will it not? Thanks!
#2246
So i see everyone uses either lift blocks or springs to raise their crv's. But has anyone tried full coil overs? Not talking coilover sleeves.
#2247
Yes. There have been people that use a taller coil on coilovers to attain a lift. Kind of overkill though as spacers do the job and are cheaper.
Berz out.
Berz out.
#2248
