whistling sound?
Old 02-16-2011, 11:01 AM
killa69er's Avatar
Default whistling sound?
Okay so my 91 civic is making a whistling sound under light acceleration I haven't heard it while I'm sittin at idle but it's very annoying as a drive has anyone ever encountered this problem I need help tracking it down any help would be appreciated
Old 02-16-2011, 11:21 AM
Keyboard Humorist
4drEF's Avatar
Default Re: whistling sound?
Bubb Rubb?
Does it only do it while in gear or can you hear it while coasting in neutral?
Old 02-16-2011, 11:49 AM
VAZQU3Z90R3X's Avatar
Dude its Normal i bet you have a cheap filter on ur intake right? anyways just upgrade to a name brand filter like aem or k&n and problem solved Good Luck..
Old 02-16-2011, 11:52 AM
KINGVEM^^ED6's Avatar
damn thats harsh for ur first post^
if u dont have a aftermarket intake
check the hose going from the head to the intake tube
mine was doing the same **** last week
Old 02-16-2011, 11:59 AM
HARSHH DOGG LIKE BUNK WEED LOL BUT A SIMPLE FIXX JUST BEiNG FRANK.. PIECE iT
Old 02-16-2011, 12:11 PM
nineohnine's Avatar
i got the same problem to on my ls swap never did it before the swap (with same intake/filter) but has always done it AFTER the swap... and i have no idea what it is... tho i have just learned to deal with it
Old 02-16-2011, 12:29 PM
killa69er's Avatar
sorry about no to maybe details... i was posting this from my phone..
91 civic zc sohc stock air box.. and fram filter it just started this.. and it kinda sounds like its under the dash somewhere?
i bought the car from a kid that "tried" to wiretuck it and i have been routing wires and vac line and trying to get them in the right spot..
if i give it a little gas on the highway i can hear it. if i give more gas it goes away. and then also when i let off the gas it goes away as well..
Old 02-16-2011, 12:41 PM
stackedhouse's Avatar
there should be a little screw on the throttle body unscrew that a little fixed my whistling problem
Old 02-16-2011, 01:40 PM
My old title sucked.
LudeEFv2.4's Avatar
Hopefully you will not last long.
Old 02-16-2011, 04:07 PM
99_Taco_Supreme's Avatar
Throttle body spacers make a whistling noise sometimes. You have one of those installed?
Old 02-16-2011, 05:06 PM
killa69er's Avatar
no tb spacer as i said sounds like inside the car? under the dash or near the cluster
Old 02-16-2011, 06:37 PM
might be ur intake mani. gasket heard that before
Old 02-19-2011, 11:27 AM
91ef-si's Avatar
Unscrew the screw on the throttle body a little bit and that should fix it. But if it doesnt start checking for vacume leaks
Old 02-19-2011, 03:22 PM
sde780's Avatar
inb4 "my cars idling real low help!"
it's probably your intake mine did it on my GSR and my prelude does it too. With no intake on the throttle body it still whistles
Lucman
06-25-2009 09:56 AM
CrazyRexBoy
12-03-2006 10:58 AM
HondaMike17
01-18-2006 08:55 AM
jiggagnome
Honda S2000
22
01-23-2005 03:54 PM
Quick Reply: whistling sound?
