what are the symptoms of a slipped timing belt?
Old 11-19-2002, 06:14 PM
Chris_'s Avatar
Default what are the symptoms of a slipped timing belt?
my brothers 91 crx si is not starting...or it will start for a second and then die out...we have replace the cap, rotor, plugs, and wires, and are definitely getting spark.
We removed the timing belt cover and noticed that the timing belt was very loose (about an inch of play). So what are the symptoms when starting a motor with the timing belt slipped a tooth?
I know how to line up TDC on the crank and cam pulleys...just haven't done it yet cuz the battery is dead
Old 11-19-2002, 06:15 PM
ImportHatch's Avatar
Default Re: what are the symptoms of a slipped timing belt? (crxconnection)
Do it with a socket and breaker bar. Then you can see whats up.
Yager-
Jaynik
20
10-20-2010 06:19 PM
1slow_si
09-23-2004 02:34 PM
GSRaCeRbOI
10-22-2002 06:34 PM
Finest
10-08-2002 07:01 AM
Quick Reply: what are the symptoms of a slipped timing belt?
