What internals should i use in my b18a1 block?
I am trying to figure out what rods and pistons i should use in my b18a1 block
I have b16 rods but not sure if they would down grade the motor
I also have stock ls rods and pistons
but i want to know if i use ls rods what pistons i should use?
Re: What internals should i use in my b18a1 block? (jdmbeegee)
the b16 rods wont work they're to short..
do you want a higher compression or lower compression? if you want lower just stick with the ls pistons,if you want a bit higher get the b16 pistons
Re: What internals should i use in my b18a1 block? (Mr.speaker)
o ok ya i want higher so ya should i just use ls pistons and rods in that case
get some wiseco pistons and eagle h beam rods. then get your head ported and polished with some new high performance values and springs, and some gsr cams. then if ya wanna have some fun, throw 10psi in and call it a day.
Re: What internals should i use in my b18a1 block? (HFpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HFpower »</TD></TR><TR><TD CLASS="quote">p30 pistons on Ls rods </TD></TR></TABLE>
x2
x2
mr.si1
10-18-2006 10:31 AM
RacerBoy
01-03-2003 12:04 PM
