What to do when your brake bleeder screw is stuck
Old 01-21-2003, 03:09 AM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Default What to do when your brake bleeder screw is stuck
Literally the screw broke off when I was turning it
the top part broke off and now it is stuck
do I have to replace the whole thing including the trailing arm or just the circle
man its a pain in the *** screwing around with shoes
Old 01-21-2003, 03:47 AM
keithv's Avatar
Default Re: What to do when your brake bleeder screw is stuck (MugenHonda)
actually all you need it a new wheel cylinder. its about $30 new from an auto parts store.
to get to the wheel cylinder, though, you will need to remove the drum shoes...
Old 01-21-2003, 05:50 AM
REDBARON's Avatar
Default Re: What to do when your brake bleeder screw is stuck (breaka_1_9)
Exactly what Breaka_1_9 said. You have to replace the wheel cylinder which is inexpensive. It's actually pretty easy to install too. I did it for the first time to my brother's CRX and it took me about 45 minutes. Mind you I was doing it pretty slow since I was reading the instructions from a book.
Old 01-21-2003, 06:11 AM
kyle h.'s Avatar
you might want to replace both while your at it. so you dont get uneven wear on the shoes. just a thought.
Old 01-21-2003, 06:54 AM
keithv's Avatar
Default Re: What to do when your brake bleeder screw is stuck (kyle h.)
very good point...
one thing i remember is that the "aftermarket" bleeder screw that comes with the wheel cylinder has a smaller size "nut". the stock rears take an 8mm wrench and i think the ones i got are like 6mm or so...
Old 01-21-2003, 07:51 AM
RCautoworks's Avatar
Mine did the same thing, my mechanic said the best bet is to by a new caliper.
Old 01-21-2003, 08:05 AM
keithv's Avatar
Default Re: What to do when your brake bleeder screw is stuck (90blackcrx)
we are talking about rear drums here, very different than rear discs. if it were a rear disc, then yes, a new caliper would probably be the only route.
Old 01-21-2003, 08:06 AM
Dam, I should of relized, my bad
nycpatron
03-07-2010 07:08 AM
pdx_503
01-22-2008 10:39 AM
Milano97
10-27-2006 10:28 PM
Seatown
08-24-2006 06:02 PM
TheSSG
06-05-2004 11:52 PM
Quick Reply: What to do when your brake bleeder screw is stuck
