TRANSMISSION IDENTIFICATION
Old 08-04-2008, 01:30 PM
mcj_420's Avatar
Default TRANSMISSION IDENTIFICATION
WELL I JUST BOUGHT A USED TRANSSMISION FOR MY 91 CIVIC AND WHEN I WENT TO GO PUT IT IN THE SPLINES DIDNT LINE UP, SO I CALLED THE PEOPLE THAT SOLD ME MY CLUTCH AND THEY SAID IT HAD TO BE A 21 SPLINE INSTEAD OF THE 20 SPLINE, SO WHAT MY QUESTION IS, WHAT ARE THE DIFFERENCES IN THE TWO TRANNYS, IM AFRAID THAT IT MIGHT BE A 4 SPEED OUT OF THE 88 CIVIC. IF IT IS CAN I GET MY TRANNY GUY TO TAKE THE DIFFERENTIAL OUT OF THE GOOD TRANNY AND PUT IT IN THE OLD ONE WITH THE BAD DIFFERENTIAL. WHAT I WANT IS THE 5 SPEED TRANNY. ANY ADVICE WOULD BE APPRICIATED.
Old 08-04-2008, 01:39 PM
meandino's Avatar
Default Re: TRANSMISSION IDENTIFICATION (mcj_420)
What are the tranny codes?
Old 08-04-2008, 02:00 PM
mcj_420's Avatar
Default Re: TRANSMISSION IDENTIFICATION (meandino)
OK FOR THE TRANNY I JUST BOUGHT THE CODE IS...L3-1159535 AND FOR OTHER BROKEN TRANNY THE CODE IS...L3-1356872
Old 08-04-2008, 02:08 PM
dr_latino999's Avatar
The L3 codes mean diddly. The 21 spline transmission shows that is from an 88 model, which one specifically is left up to positive gear identification or through further stamp identification. If you are so worried that it could be a four speed just shift it by hand or open it up. Hell, if you open it up it'd be a good lesson on how to count teeth on the countershaft / final.
Anyways, look here --> https://honda-tech.com/zerothread?id=1551508
Old 08-04-2008, 02:39 PM
mcj_420's Avatar
Default Re: TRANSMISSION IDENTIFICATION (dr_latino999)
OK YEA IT IS A 4 SPEED TRANNY. NOW WILL I BE ABLE TO TAKE THE DIFFERENTIAL OUT OF THAT ONE AND PUT IT IN MY 5 SPEED TRANNY. THEY SHOULD BE THE SAME RIGHT?
Old 08-04-2008, 03:07 PM
Natural Aspirations's Avatar
Easiest way to tell is check part numbers here
http://www.hondapartsdeals.com
Old 08-04-2008, 03:14 PM
mcj_420's Avatar
Default Re: TRANSMISSION IDENTIFICATION (Natural Aspirations)
YEP THEY'ER THE SAME PART NUMBERS. THANKS FOR ALL YOUR HELP. ILL GET MY TRANNY GUY TO SWAP THOSE OUT THEN. OR IS IT EASY ENOUGH TO DO MYSELF?
Old 08-07-2008, 01:47 PM
mcj_420's Avatar
Well just to give you guys an update on my tranny... I went to my guy this morning and we took the old tranny apart and found that is was beyond repair. Not only was the differential completely jacked up so was 5th gear. So then we took apart the new one i just bought to see if we could take some of the parts off it to fix to it but once we opened it we saw it was a 5 speed and that it was in perfect condition. So what im doing now is i bought the 21 spline clutch disk for my good tranny (only $25 plus shipping) and im just gonna use that good tranny. And just so you know its not easy swapping out differentials without someone that knows what their doing. Too many little parts and thiers a little trick to it that i didnt really understand. But now i know how to break in half the tranny and count my gears. (good thing to know)
tegsp
06-27-2005 12:32 PM
h22 civic
10-25-2004 03:26 PM
hi-Powered
05-06-2003 01:39 PM
Quick Reply: TRANSMISSION IDENTIFICATION
