Tool for O2 sensor?
Tool for O2 sensor?
I have read conflicting information condering this when I search. I have heard I need a 7/8" wrench, or a 22mm wrench, or an O2 sensor tool. I would prefer not to remove the fan, but if I have to I will. Can anyone confirm the tool needed?
Re: Tool for O2 sensor? (shbrown)
The O2 sensor tool is ~$10 at most discount auto places or Harbor Freight tools. It makes removing the sensor much easier, because it is difficult to get a regular wrench so close to the manifold and still have room to turn it.
Re: Tool for O2 sensor? (fireant)
you can check out an o2 sensor for free at autozone (they charge $16 to your c.c. and refund it when you bring it back)
7/8" = 22mm roughly.
the 02 sensor tool is only worth it if you are using an impact gun, or really need to use a cheater bar, which is used instead of a normal socket.
the issue is the sensor wire that prevents using a normal socket.
i prefer just using a 22mm box end wrench tho.
