timing marks diaphram
Old 11-06-2008, 08:22 AM
builtsinglecam's Avatar
Default timing marks diaphram
can anyone show me the exact timing marks on the pulley and cam gear?
Old 11-06-2008, 08:33 AM
jlicrx's Avatar
Default Re: timing marks diaphram (builtsinglecam)
which engine? - this is the diagram for the 88-91 CRX/Civic engines - please note that the Si D16A6 is different from the D15 engines:
this is what the marks on the crank pulley look like:
Old 11-06-2008, 08:48 AM
Default Re: timing marks diaphram (jlicrx)
i have a d15b7 it should be the same but so the red mark on the pulley gets set between the two notches correct
Old 11-06-2008, 09:04 AM
anyone?
Old 11-06-2008, 10:22 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builtsinglecam &raquo;</TD></TR><TR><TD CLASS="quote">i have a d15b7 it should be the same but so the red mark on the pulley gets set between the two notches correct </TD></TR></TABLE>no - the three marks together are the ignition timing marks - TDC is the white mark, all by itself, off to the right of the three marks - labeled 'B' in the lower picture - the white mark lines up with the pointer on the cover for TDC
Old 11-06-2008, 02:28 PM
hey thanks (jlicrx) it helped out alot its got more power in it rite on
Old 11-07-2008, 11:41 PM
HTautodc's Avatar
hello. i'm a noob here. why is it that there are 2 pointers? the one on top and the one below? and what's the purpose of those ignition timing marks? sorry for the noob question. i tried adjusting my timing before but i only adjusted 2 cylinders (total of 6 valves) since i had a feeling i wasn't doing it right. thanks
Old 11-10-2008, 10:52 PM
HTautodc's Avatar
i get it now, sorry. the 3 marks are for the degrees. the center mark is what i would look for using the light. thanks
blue_hatch
09-07-2007 10:38 AM
4gencivicef9
06-14-2007 06:27 PM
MenaceL.A.671
09-13-2005 04:10 PM
onedgemotorsports
11-24-2004 05:46 AM
Quick Reply: timing marks diaphram
