Starter probz
Starter probz
Some background: i have a gsr motor in my crx, my battery is located in my trunk. I'm using 4 gauge wire with 150amp hooked up.
So my starter has been clicking for a while and when i bought the rebuild kit even with the plunger, It still kept clicking. Bought a new starter and it still clicks when i try to start it. So could that mean my battery sucks? I have a Deka ETX16 Battery and i've only had it for a year. I'm getting really tired of my car not starting right away. The clicking is random. I've noticed most morning it will start up instantly, then when i drive for a while and stop, it will take some clicks until it finally starts.
Re: Starter probz
You are definitely looking in the right direction by thinking it is the battery.
Clicking happens when there is not enough voltage getting to the starter.
Go to your local parts store and get them to test the batery for you.
***Or test it yourself if you have a voltmeter/multimeter.
If you have less then 9.5 Volts across the battery when cranking the engine over, it is a sign that you battery is on its way out.
Not sure what you mean when you say you have "150amp hooked up". Are you referring to your alternator or do you mean a 150 Watt Amplifier?
Re: Starter probz
And sorry, I meant an inline fuse. It's actually a 100amp maxi inline fuse.
I checked grounds and looked at some connections for corrosion, but i didn't find any. Should i be using a thicker gauge power wire?
Re: Starter probz
What gauge are you running? And do you have any problems with yours?
Trent89
13
07-11-2013 09:15 AM
