Lookie what I just got.... Need help finding the diagnostic plug....
Old 07-30-2005, 07:40 PM
Skoobie no more...
HatchBox's Avatar
Default Lookie what I just got.... Need help finding the diagnostic plug....
Pictures speak for themselfs. Its the way honda used to check cars before they went to the whole laptop deal.
(for those who dont know, it shows you all the info that the ecu is receiving. i.e. Tps voltage, o2 sensor voltage and injector fire time.)
Obd0 plug.>
Can anyone tell me where to locate this damn plug....or tell me where the 3 wires run too?
I was told its right behind the glove box...
Old 07-30-2005, 08:05 PM
Voodooboy520's Avatar
Man, whered you get that thing? Nice
Old 07-30-2005, 08:06 PM
dr_latino999's Avatar
Default Re: (Voodooboy520)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voodooboy520 &raquo;</TD></TR><TR><TD CLASS="quote">Man, whered you get that thing? Nice </TD></TR></TABLE> And how much did that run you?
Old 07-30-2005, 08:10 PM
Skoobie no more...
HatchBox's Avatar
Default Re: (dr_latino999)
im borrowing it from a friend, his dad works for honda
he had it laying around....
but back to the topic at hand, anyone have a helms. Maybe that will show the location of the connector?
Old 07-30-2005, 08:58 PM
HICOMPCRX's Avatar
Default Re: Lookie what I just got.... Need help finding the diagnostic plug.... (HatchBox)
Unless your car is obd1 or obd 2 then the pgm tester is useless to you.
The 3 wire plug that you posted is for obd1 and there is another adapter to hook up to obd 2 car(I see it in the box).
Its pretty good to use, I just converted my crx to obd1 p28 and used the tester to help fix my o2 problem, but the newer HDS tablet is alot better. good luck
Old 07-30-2005, 09:00 PM
Skoobie no more...
HatchBox's Avatar
Default Re: Lookie what I just got.... Need help finding the diagnostic plug.... (HICOMPCRX)
bah, your 100% sure no 0bd0 cars had diag connectors?
Old 07-30-2005, 09:06 PM
I3ackfire's Avatar
Default Re: (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">im borrowing it from a friend, his dad works for honda
but back to the topic at hand, anyone have a helms. Maybe that will show the location of the connector? </TD></TR></TABLE>
Well if your buddies dad work's for Honda, and he let you borrow that, why don't you just ask him???
Old 07-30-2005, 09:12 PM
Bjorn20's Avatar
um, dong u just plug that into the little hookup under the drivers side harness,, kinda where the gas/brake pedal is. or is that for something else?
Skoobie no more...
HatchBox's Avatar
Default Re: (I3ackfire)
because i cant get ahold of him now , not till monday. So I was going to try to work on it some today..
Old 07-30-2005, 10:05 PM
Needs to be About 20% Cooler
DieMaster's Avatar
i would give my left nut for a tester like that anyone know where or IF they can even be found anymore?
Old 07-30-2005, 10:42 PM
HICOMPCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">bah, your 100% sure no 0bd0 cars had diag connectors?
I'm pretty sure for hondas...I dont know about other manufactures. Your car may have a 2 pin connector around the ecu area... but that is for timing (some 2 pin connectors may be under the hood depending on year/make/model).
If you open up the big door in the testers case the operating maunual may be in there.(not shown in your pic.)
Old 07-30-2005, 10:46 PM
HICOMPCRX's Avatar
Default Re: (DieMaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster &raquo;</TD></TR><TR><TD CLASS="quote">i would give my left nut for a tester like that anyone know where or IF they can even be found anymore?</TD></TR></TABLE>
You can find them on ebay or you can buy one from MAC tools...
It's called a MasterTech and made by Vertronics, if you buy a used one it may or may not come with the Honda module card, If not you can buy the honda program and transfer it over the the testers memory card if it comes with it or not.
Old 07-30-2005, 10:50 PM
HICOMPCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">because i cant get ahold of him now , not till monday. So I was going to try to work on it some today.. </TD></TR></TABLE>
You should aleast plug it into your accord(in sig) and play around with it.
Old 07-31-2005, 01:30 AM
michael O's Avatar
Default Re: (HICOMPCRX)
HICOMP is right. There isn't going to be a diagnostic plug for obd0.
totsie7944
04-16-2008 06:04 PM
nerdboy1024
20
09-24-2007 04:40 PM
Joey.
04-20-2006 03:41 PM
DraconicPenguin
13
10-28-2005 07:03 PM
silentblackhat
11
02-16-2005 09:37 PM
Quick Reply: Lookie what I just got.... Need help finding the diagnostic plug....
