SEARCHED! TDC on the fllowing cylinders, how many turns?
Old 11-01-2004, 06:52 AM
EF9Si-T's Avatar
Default SEARCHED! TDC on the following cylinders, how many turns?
I searched already and found alot of info but not what i want. After I get TDC on cyli 1, How many turns do i give to the crankshaft to get TDC for the following cylis? I was told to do it in the fring order that much I know. A6 F.O. 1-4-3-2 is this correct? Thanks, after you guys help me out I will start Valve Adj.
Modified by BUG_MANIAC at 4:19 PM 11/1/2004
Old 11-01-2004, 08:52 AM
EF9Si-T's Avatar
Default Re: SEARCHED! TDC on the following cylinders, how many turns? (BUG_MANIAC)
ANYONE!
Old 11-01-2004, 08:59 AM
MENACE's Avatar
I think you turn the crank 90 degrees. Well at least that make sense IMO. Most of the time when i Adjust the valves i just look and the Rockers till the look Like they are at TDC. Then Inspect the cam to make sure im not on the lobe. Maybe i do it the hard way but i want to make sure, and i dont wanna **** with how many turns did i just do bullshit.
Old 11-01-2004, 09:23 AM
UltimX's Avatar
Default Re: SEARCHED! TDC on the following cylinders, how many turns? (MENACE)
If I remember correctly, its 180 degrees from TDC. 90 will put the pistons in line with each other.
Old 11-01-2004, 09:42 AM
MENACE's Avatar
Default Re: SEARCHED! TDC on the following cylinders, how many turns? (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">If I remember correctly, its 180 degrees from TDC. 90 will put the pistons in line with each other.</TD></TR></TABLE>
Youre Right 90 for the head 180 for the crank. Crank spins twice as fast. haha i see where i got confused lol.
Old 11-01-2004, 09:48 AM
TrueNorthStar's Avatar
Its all in the cam gear/gears:
Looking at the arrows on your cam-gear/gears
SOHC/DOHC
^ or ^^ = Cyl#1 @ TDC
&lt; or &lt;&lt; = Cyl#3 @ TDC
v or vv = Cyl#4 @ TDC
&gt; or &gt;&gt; = Cyl#2 @ TDC
Firing order is 1-3-4-2
Old 11-01-2004, 11:02 AM
EF9Si-T's Avatar
Default Re: SEARCHED! TDC on the following cylinders, how many turns? (TrueNorthStar)
Can you explain this a little more in detail, sorry.Do you mean the UP marking ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">Its all in the cam gear/gears:
SOHC/DOHC
jdm_manny
12-01-2009 07:35 PM
FuNkDrSpOt
12-19-2008 06:24 AM
djhatchtraxxx89
10-04-2006 03:46 PM
integracivic94
08-07-2003 12:35 PM
integracivic94
08-07-2003 08:47 AM
Quick Reply: SEARCHED! TDC on the fllowing cylinders, how many turns?
