car will crank but wont start after replacing timing belt
Old 09-20-2012, 10:13 AM
thekeysarebroke's Avatar
Default car will crank but wont start after replacing timing belt
Its an 89 Honda Civic Dx.
Was driving home and the timing belt broke, I was in 2nd or 3rd gear when it happened.
It was a friend who replaced the timing belt and water pump, we've also replaced the spark plugs, fuel pump and filter. The car still won't start, and i'm going to talk to a mechanic today. any ideas? could the valves be bent?
Old 09-20-2012, 11:23 AM
droopy128's Avatar
Default Re: car will crank but wont start after replacing timing belt
Timing probably off during reinstall.. check timing again (TDC) is it align correctly.
Old 09-20-2012, 01:00 PM
nicknack25's Avatar
What droopy said. Pretty sure timing is off. did you change fuel pump plugs and filter after you found out it wasn't starting? or all at the same time?
Old 09-20-2012, 01:11 PM
10psiLsEf2's Avatar
recheck timing
when you installed and timed the belt. after it was all tight did you rotate the crank 2 times through all the strokes? and then realign iit at tdc and check the marks?
i dont believe this engine is a contact engine but i could be wrong. it could also be bent valves.. but you can tell by sound.
does it turn over slow or super fast?
do a compression test. but first re check timing.
Old 09-20-2012, 02:06 PM
jchope's Avatar
your timming is off
Old 09-20-2012, 02:08 PM
Former User's Avatar
Originally Posted by 10psiLsEf2
it could also be bent valves...do a compression test. but first re check timing.
This^
Old 09-20-2012, 03:59 PM
trojwl's Avatar
Put crank at TDC. There are marks on cam sprockets that need to be in correct position. Get a manual or look on-line. You may have to do more than one revolution of crank as cam rotates one-half as fast as crank. It will be obvious.
You may be 180 degrees off on camshaft (or 360 off crank -same diff). When a plug sparks, the valves should both be closed for that cylinder. If you're off on cam timing, the valves will be in wrong position when cylinder is sparked and motor cannot possibly run.
And YES - IT IS AN "INTERFERENCE" MOTOR. There will be damaged valves unless you are very lucky.
By all means, at least get a Chilton's manual down at Autozone.
Old 09-20-2012, 04:02 PM
10psiLsEf2's Avatar
Sorry for the wrong info bud!
before jumping to conclusions just set timing once more... if tht dont do it. do a comp test
let us know the results
Old 09-26-2012, 04:09 AM
turns out it was a bent valve, the timing was fine. I decided to go ahead and get it fixed
Old 09-26-2012, 06:23 AM
trojwl's Avatar
Triple check the marks on the cam and crank at TDC when reassembling..
That's pretty much the only way you can bend a valve.
Good luck.
Old 09-30-2012, 05:27 AM
Well i got it back from the shop yesterday and everything seemed to be going good. but then after about 30 minutes of driving the check engine light turns on. when i pulled over i noticed there was white steam coming up from the engine, the car wasn't over heating before i pulled over.
I didn't see any coolant leaking
Old 09-30-2012, 05:57 AM
trojwl's Avatar
Can you pinpoint where on the engine the steam is coming from? The coolant will flash as soon as it hits atmosphere. And if it's on an upper point on the engine, the coolant has merely leaked down below the leakpoint and thus you won't see any liquid leaking.
I would top off coolant, start car, watch closely and see where problem first developes.
Also check oil level and check for water in oil (will look milky). If coolant is somehow leaking at head gasket and into coolant chamber, then you will have a real probelm to address (probably head gasket). I've seen this happen before.
Good luck and keep posting progress.
Warren
Old 09-30-2012, 06:19 AM
I really hope it's not the head gasket, but the repair shop did replace the head.
it doesn't look like it's holding oil at all, but i don't see a leak
Old 09-30-2012, 07:34 AM
10psiLsEf2's Avatar
i would say the steam is actually burning oil,grease.etc From the shop. check what dtc came on
Old 09-30-2012, 09:29 AM
trojwl's Avatar
The smell of the steam will be a tell-all (coolant vs. oil - very distinctive odors).
Old 10-01-2012, 05:35 AM
Jockone's Avatar
If you had a shop replace the head then take it back to them to have the job redone if you have a problem,but make sure that you don't just have oil and grease burning off from them doing the job.
ddn1313
08-04-2018 02:46 PM
Macnotiss
10
10-18-2017 05:44 PM
Jack Shephard
12
02-13-2009 06:27 PM
nighttrain33
03-23-2008 01:38 PM
GroundZer0 336
13
05-24-2004 09:27 PM
Quick Reply: car will crank but wont start after replacing timing belt
