No Breaklights and Sealtbelt/Door ajar light always on??
recently my dash has been goin crazy on it.. it saying that my door is open and my seatbelts aren't on.. well thats how it startd.
about a week later, i plug the seatbelts back in under the seats, and now it is messd up even more, it tells me i dont have my seatbelts on and door open when i hit the brakes, and when i hit the horn..
now to add to the confusion, my brake lights have recently gone out.. car needs inspected this month and well it wont pass if i dont get that fixd
any ideas where/what to look at? im assuming i have to gut the interior to check all the wiring, was hoping there was a better solution though
btw i have 91 si
btw i have 91 si
check your horn fuse in the underhood fuse box. My frined used to have a 91 crx and his brake lights stopped working changed all the bulbs, new switch on the pedal, and it was the horn fuse.
ok i go check that now... my tail lights use to work before i realised the horn was gone, once i tried to hit the horn and it just stopd and the break lights went out
h224thgensedan is right i had this problem becouse of someone leaving leaving hot wires under my dash from an old alarm the horn/brake lights fuse went out and i swapped 15A fuse
wow thanxs alot... i forgot about the fuses under the hood... changed the 15a fuse and horn/brake lights work again thanxs!!!
not sure if seatbelts work or not yet... doin other thing to the car atm and its not driveable
boostedef123
32
08-09-2011 08:29 AM
trex352
01-29-2007 04:52 PM
trex352
01-27-2007 02:50 PM
