My car is dieing!!!???
Old 08-01-2002, 02:13 PM
simike's Avatar
Default My car is dieing!!!???
I have an 89 crx si. The motor is all stock. I got the car cheap because it had problems. I was told it had a blown headgasket. I put a new head gasket in it timing belt water pump ect..... As far as i know the timing was never right since i did the head gasket. It pulled as good as my frineds 91 si but the motor was always noisy.
For the past 2 weeks when i start the car it idle's rough and sometimes stalls. If you rev the motor a couple times it goes away or if you start to drive it it goes away. When you drive the car it runs good just noisy.
Today i went into Wawa and when i came out and started the car it left out a huge puff of white smoke along with the ruff idle. Does anybody know what could be wrong? Blown head gasket again? Why? Any help would be great. Also when i put the new headgasket in i had the head decked to make sure it wasn't warped. All this was done about 6000k miles ago.
Old 08-01-2002, 02:39 PM
Malgerus's Avatar
Default Re: My car is dieing!!!??? (simike)
sounds like the head gasket to me... did you install it properly?? like retorquing the head bolts and such?
Old 08-01-2002, 03:18 PM
simike's Avatar
Default Re: My car is dieing!!!??? (89_Y_49)
Retorqing the head bolts? I torqed them when i put it on but was i supposed to go back and re torq it after a certain # of miles or something?
Old 08-01-2002, 06:23 PM
D-Man's Avatar
u shouldve rechecked the torque after the 1st time you started it with the new head gasket
[Modified by D-Man, 10:24 PM 8/1/2002]
Old 08-01-2002, 06:56 PM
blacksoul's Avatar
The head gasket may have not sealed correctly, do a compression check or leak down test.
Old 08-01-2002, 07:18 PM
EdianTfw's Avatar
Default Re: My car is dieing!!!?? (blacksoul)
The leak down test.
Old 08-02-2002, 01:29 PM
simike's Avatar
Default Re: My car is dieing!!!?? (EdianTfw)
How important is it to replace the head bolts when you do a head gasket? What should my compression be at? Thanks for the replies.
keljohns992
Honda Civic (2001 - 2005)
12-14-2013 04:25 AM
hondarondon9296
09-20-2009 09:00 PM
PinoyDelS0l
06-05-2009 01:03 PM
lluks_844
32
03-29-2008 10:40 PM
90LSpimpin
10-12-2004 09:31 PM
Quick Reply: My car is dieing!!!???
