Mini me
Old 08-28-2004, 10:08 PM
gutted-dx's Avatar
Default Mini me
Can i do a Mini me on a d15b2 Dual point motor what would i need which head would be easiest
Old 08-28-2004, 10:41 PM
Redline130's Avatar
Default Re: Mini me (gutted-dx)
Yes you can use a B2 bottom. I have one in my 88 hatch right now. If you can, find a D16Y8 head and intake manifold. The OBD0 distributor will bolt up to the Y8 head much easier than the Z6 head. However, the Z6 head will probably be cheaper.
Old 08-29-2004, 07:28 PM
gutted-dx's Avatar
ttt can i use the dual point intake manifold or do i have to convert the harness
Old 08-29-2004, 07:31 PM
EJ2-Fluffy's Avatar
Default Re: (gutted-dx)
you will have to convert to MPFI im guessing since that's what the new head will be using. Y8 is the best bolt on..but yes the Z6 will be the cheaper one to get. Both work, just gotta make the Z6 fit.
-Jon
Old 08-29-2004, 08:01 PM
EF9Si-T's Avatar
Default Re: Mini me (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can use a B2 bottom. I have one in my 88 hatch right now. If you can, find a D16Y8 head and intake manifold. The OBD0 distributor will bolt up to the Y8 head much easier than the Z6 head. However, the Z6 head will probably be cheaper. </TD></TR></TABLE>
Can this be done and keep the a6 intake manifold,injectors and sensors and keep it OBD 1?
Old 08-29-2004, 10:48 PM
Redline130's Avatar
Default Re: Mini me (BUG_MANIAC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUG_MANIAC &raquo;</TD></TR><TR><TD CLASS="quote">
Can this be done and keep the a6 intake manifold,injectors and sensors and keep it OBD 1?</TD></TR></TABLE>
You could use the A6 parts you listed except the injectors if you want to convert to OBD1. If you wanted to stay OBD0, then use the A6 or any other OBD0 injectors and injector resistor.
Old 08-30-2004, 01:22 AM
jessevtec's Avatar
would you need a p28 ecu also?
Old 08-30-2004, 05:49 AM
green91's Avatar
as long as you keep the resistor box i think u can use the a6 injectors. I never did mini-me on my b2 because i thought you needed a cam gear.. id always read timing was 1/2 tooth off
Old 08-30-2004, 07:19 PM
gutted-dx's Avatar
So i could'nt just bolt the intake up, because i really don't want to convert the harness
Old 08-30-2004, 10:51 PM
Redline130's Avatar
If you want to use the MPFI intake manifold, you have to convert your harness. There is no other way around it....2 injectors vs. 4 injectors....
Old 08-31-2004, 06:21 PM
gutted-dx's Avatar
All i need is a straight answer, can i bolt a vtec head in and use the dualpoint intake manifold.
Old 08-31-2004, 06:26 PM
Gant's Avatar
NO
Old 08-31-2004, 08:47 PM
crxdx89's Avatar
if u want, i got almost everything for the MPFI swap. JoshRM87@wmconnect.com
either OBD1 or OBD0, have manifolds and injectors for either
Old 09-06-2004, 05:48 PM
gutted-dx's Avatar
On the Dual point could i use DSM 450 injectors for the two shitty ones or would it be two much fuel
Old 09-06-2004, 06:08 PM
shocker's Avatar
Dude you gotta convert to mpfi if you wanna do any swap,get rid of that dumb excuse for an intake manifold.
Old 09-06-2004, 06:09 PM
kid-honda's Avatar
Default Re: (CRX-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">you will have to convert to MPFI im guessing since that's what the new head will be using. Y8 is the best bolt on..but yes the Z6 will be the cheaper one to get. Both work, just gotta make the Z6 fit.
-Jon</TD></TR></TABLE>
Make the Z6 fit? it bolts on like the Y8.
Old 09-06-2004, 06:50 PM
crxdx89's Avatar
Default Re: (kid-honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda &raquo;</TD></TR><TR><TD CLASS="quote">
Make the Z6 fit? it bolts on like the Y8.</TD></TR></TABLE>
yes it does bolt on, BUT, if u stay OBD-0, then u have to either fab an adapter plate for the a6 dizzy, or hack it up for it to fit good on the z6 head.
Old 09-06-2004, 07:56 PM
ihateslowhondas's Avatar
the easy way to mini me a dpfi car....
*buy a z6head, that is the easiest to work with and the obd1 setup is easier to run
*use the z6dizzy
*buy a obd0 to obd1 conversion harness from boomslang fabrication(i will vouch for his high quality)
*use p28 or p08(jdm ecu)
* you will need a obd1 wire harness to hack up
when you do the conversion you will best off to use your dx wiring harness. just add connectors off of a obd1 harness for the dizzy plugs and injectors and a few others to your dx wiring harness. you will need to run 4 extra wires directly from the ecu for the dizzy and 2 of your injectors, using obd1 injectors you canconnect all the grounds off of the injectors to the 2 injector grounds on the dx harness. to gather all your info on this swap with illustrations search for (mpfi swap) and (obd0 to obd1 conversion)
Old 09-07-2004, 04:21 AM
gutted-dx's Avatar
The y8 is the easier one to mini me because the a6 dis, will bolt up to the y8 head
Old 09-07-2004, 10:45 PM
it doesnt matterif you use the obd0 distributor, it still wont run right , your vtec will only work if you use the right distributor and computer. taking shortcuts like your distributor idea or an rpm activated switch have no advantages and will not work out. convert it to multi point obd1 you'll be much better off this way and not slow as heck lool
Old 09-08-2004, 05:11 AM
green91's Avatar
obd0 will work fine with it, i run turboedit and can easily run vtec as well if not better than a p28 for much less than the cost of obd1 conversion
Old 09-08-2004, 10:11 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gutted-dx &raquo;</TD></TR><TR><TD CLASS="quote">All i need is a straight answer, can i bolt a vtec head in and use the dualpoint intake manifold.</TD></TR></TABLE>
Yes you can but whats the point.. Going from dpfi to mpfi will give you more of a power jump then going to a vtec head would..
Red_ED8
12-06-2007 11:22 AM
SpdFrk
04-23-2006 07:47 PM
specificcivic
03-30-2004 01:17 PM
EK_vzla
01-31-2004 10:52 PM
one.EG6
04-30-2003 05:06 PM
Quick Reply: Mini me
