LEAKING OIL FROM FILTER HOUSING!! HELP!!
Old 03-21-2010, 06:32 PM
puertoricanboy90's Avatar
Default LEAKING OIL FROM FILTER HOUSING!! HELP!!
so... my "new" Rex is leaking oil. Aside from pissing me off and being an inconvenience because I have to keep adding oil, the location of where the oil is coming from is horrendous. It is leaking from being the oil filter housing... now here is where the dilemma comes in to play. I have a third gen ZC DOHC motor. I know the D16A1 is very similar in design, so here comes my next questions. A: is this oil filter housing removable or integral with the block? B: would the D16A1 be similar enough in design that [if it is possible] I could buy and use the oil filter housing for that car?
Any, real, advice would be awesome. Thanks.
Old 03-21-2010, 06:36 PM
Jockone's Avatar
Default Re: LEAKING OIL FROM FILTER HOUSING!! HELP!!
Do you mean the part with the oil cooler that the filter screws onto?
Old 03-21-2010, 06:52 PM
miguey310's Avatar
what kinda filter do you have ? cause sum are cheap and they don't hold the pressure and they leak , another tip is when you put the oil filter lub up the gasket with sum oil to make it seal better
Old 03-21-2010, 07:40 PM
Yes. That part with the bypass hose for oil cooling. Is it removable and/or repairable?
Old 03-21-2010, 07:41 PM
Bosch filter. But it doesn't matter what kind I have because that is not where the leak is coming from. It is coming from behind base of the oil filter housing. I'll take a pic tomorrow if I have time to clarify any confusion....
Old 03-21-2010, 07:43 PM
BiG ChOr!Zo's Avatar
could be the oil cooler gasket...i had the same problem with my old 92 accord and i replaced the gasket and it was all bueno...!!!
Old 03-21-2010, 07:55 PM
Do I have to go Honda for that f*cking gasket? Cuz everywhere I have called, even my tuning shops, has no listing for the part. It's driving me nuts... :/
90RENOsedan's Avatar
check and see if its double gasketed. it could be as simple as removing a stuck on gasket.
Old 03-21-2010, 07:58 PM
I think I must be severely misunderstood... there is no way this is the oil filter. It is NOT double gasketed. It is not a cheap filter. The part is called an oil filter housing. The part with spindle [that the oil filter screws on to] with the oil bypass and cooling ports. It is leaking from there....
Old 03-21-2010, 07:59 PM
88Hatchy's Avatar
I have found that is best way to get parts like these is to find the part number yourself, then just ask for the specific part at the parts counter.
Old 03-21-2010, 08:35 PM
yes you have to go and get it from the dealer...its not your oil filter but is called a oil cooler o-ring (91316-PE7-730) that is located between the oil filter housing and the block...its #19 in the diagram below for a d16a1 motor...when this o-ring goes bad it starts leaking a ton of oil and at first i thought my block was cracked but it turned out to be the o-ring...!!!
Old 03-21-2010, 11:06 PM
DCRB's Avatar
the gasket is like three bux...
Old 03-22-2010, 04:46 AM
minime-dom's Avatar
i have some what of the same problem i got a d16z6 turbo and its leakin oil but i have no clue were i look under it and i cant seem to find it i think it may be leakin oil from the oil pressure switch to the turbo wut in oil line do u think i shuld get ?? or what kind of oil lines are good
Old 03-22-2010, 04:54 AM
Jockone's Avatar
Op as you can see from the exploded view posted above yes it comes apart and it is an easy fix,just as an added precaution I would get new hose or hoses for the water side of the cooler/housing while I was in there.
Old 03-22-2010, 07:11 PM
That is the plan good sir. And Big Chorizo hit the nail on the head with the diagram. I ordered the part and it'll be in tomorrow. thanks guys.
chiaxi2002
04-09-2010 08:56 PM
sextav6
11-30-2009 04:05 PM
wesk18
12-26-2008 10:56 AM
NINJA
08-02-2003 11:56 AM
degradated
10-29-2001 07:32 PM
Quick Reply: LEAKING OIL FROM FILTER HOUSING!! HELP!!
