Interesting Case of Steering Wheel vibration
Old 09-01-2014, 10:25 AM
NickH93's Avatar
Default Interesting Case of Steering Wheel vibration
Hey all, another case of steering wheel vibration. '89 CRX DX.
When I get up to highway speeds (55+ MPH), the steering wheel shakes back and forth...but only when I let off the gas? If I hit the gas, the vibration stops, and then comes back when I let off the pedal. It speeds up with the car as well.
I've heard of it happening when you brake, but not when you let off the gas. This problem sprung up after a wheel stud broke during driving and ruined all the studs and old rim. I replaced those studs, lug nuts, and got a new rim. I also just replaced the brake pads as well.
Any ideas?
Old 09-01-2014, 10:29 AM
95accordCE6's Avatar
Default Re: Interesting Case of Steering Wheel vibration
Have the tires been balanced?
Old 09-01-2014, 10:31 AM
NickH93's Avatar
Yes, tires were balanced.
Old 09-01-2014, 11:43 AM
sstupid's Avatar
Source of vibration for me was the inner tie-rod. Basically, the wheel would start to shake side-to-side during braking or deceleration. It would only happen in a certain speed range, probably due to harmonics.
Old 09-01-2014, 01:43 PM
Inner or outer tie rod is a possibility. To test this jack up the front of the car and see if there is any play from side to side, it's easiest with a friend to shake the wheel while you watch underneath to see what is loose.
Old 09-02-2014, 10:39 AM
NickH93's Avatar
I jacked the car up, noticed a lot of play in the front left wheel (which is where the stud broke off).
I can see the play in the outer tie rod, so I'm guessing that's my culprit. Even had someone move the tire with the play while I held the steering wheel...totally what I felt on the highway. Lol. All the vibration from the broken wheel stud must've messed it up. I'll replace it and see how it pans out. Thanks guys!
Old 09-02-2014, 10:54 AM
Keyboard Humorist
4drEF's Avatar
Highly recommended that you Replace tie rods on both sides of the car rather than just the one culprit.
Old 09-02-2014, 11:30 AM
NickH93's Avatar
Will do. Price is right, anyway. Might as well do stuff the right way. Lol. Thanks!
Old 09-02-2014, 12:59 PM
Glad you found it
Old 09-02-2014, 03:51 PM
sstupid's Avatar
Good to hear! Let us know how it turns out.
Old 10-24-2014, 11:40 AM
NickH93's Avatar
So I'm at my wits end here...
After this post, the vibration got much worse. I did all new brake rotors, and some of it went away. I noticed play in the upper ball joints while I was replacing the clutch (it vibrated the same before I replaced the clutch), so I did new upper control arms.
There is also a sound that sounds like it's coming from the rear left?
I can't make heads or tails of it..
Here's the list
New Tie Rod ends.
New UCAs
New Brake Rotors
Not sure what this could be, but I'm going to get it realigned. In the meantime, any other ideas?
Old 10-24-2014, 01:50 PM
Tyson's Avatar
rack end bushing and pinion adjustment.
if the steering wheel is shaking, think of the whole path from the steering wheel to the tires.
check every component along the way.
Old 10-26-2014, 03:39 PM
No Big Whoop
Spaceballsthelunchbox's Avatar
Lift the car and grab one of the front wheels at 3 and 9 ( as in the face of a clock). Rock it left to right...does it move or feel lose? Now grab the wheel at 12 and 6. Rock it top to bottom...does it move? Do that on both front wheels.
Let us know what you find.
rocru
05-29-2012 11:36 AM
p0tential
Suspension & Brakes
03-08-2008 10:20 PM
Odiedogcx
03-15-2006 10:33 AM
Prisky
04-30-2005 01:06 PM
Toda Party
10-27-2002 07:26 AM
Quick Reply: Interesting Case of Steering Wheel vibration
