icu replace?
Old 09-19-2012, 01:25 PM
wasp9166's Avatar
Default icu replace?
my intermittent wipers will work when turned on ,then they pretty much do what they want, work sometimes other times i have to wait
through a search i read it's due to bad capacitors on the icu which is under the fuse panel?
is this part no longer available from honda?
or anyone else?
91 civic dx
Old 09-19-2012, 02:49 PM
91STDFLOW's Avatar
Default Re: icu replace?
ICU controls the Inter. Wipers. Big grey gameboy looking box on the back of your under dash fuse panel, should have a big A or B depending on which one. Junkyard is where i always get them from or you can call Honda and ask.
Old 09-20-2012, 02:00 PM
wasp9166's Avatar
this is called the mcu, multifunction control unit is it not?
i'm pretty sure the ignition control unit is in the diz?
Old 09-20-2012, 02:05 PM
Former User's Avatar
It's called the ICU for 4th generation Civics.
You could also have a bad switch, which can be cleaned.
speed_demon018
05-28-2009 01:00 PM
jim747
04-09-2007 08:03 AM
droppedsi
12-09-2005 08:02 PM
munscher
03-07-2003 11:34 AM
Quick Reply: icu replace?
