JDM b16 help
Old 02-04-2008, 08:56 AM
lilhatch89's Avatar
Default JDM b16 help
Got a JDM b16 engine in 91 civic SI, Im getting plenty of fuel timing is good and im getting spark but still wont fire. car ran fine up to two days ago then it just started acting up. Checked main relay i checked timing, its all good. fuel and spark are good as well. new cap rotor and plugs and wires. any ideas.
Old 02-04-2008, 09:08 AM
civickid03's Avatar
Default Re: JDM b16 help (lilhatch89)
check your fuel return? what is your fuel pressure? check map sensor voltage, compression test, leakdown if possible.
Old 02-04-2008, 09:15 AM
lilhatch89's Avatar
Default Re: JDM b16 help (civickid03)
im getting plenty of fuel. ECU is bleaking 4 then pause then 9
Old 02-04-2008, 09:48 AM
Stouts 'n' Scotch
wiZCo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilhatch89 &raquo;</TD></TR><TR><TD CLASS="quote">im getting plenty of fuel. ECU is bleaking 4 then pause then 9</TD></TR></TABLE>
Well, no wonder it won't start.
4 is crank position sensor and 9 is the cylinder sensor. Sounds like you need to re-wire or replace your distributor.
If it was running fine a few days ago and this just started, I'd say your distributor is toast.
Old 02-04-2008, 09:56 AM
alscrx's Avatar
I believe you are throwing 2 codes... 4 and 9 correct??
4 =crank position sensor
9=cylinder sensor
Both sensors are in your distributor. I would say replace your dizzy with a known working one. Make sure to get the correct one for your motor.
SIR and XSI jdm b16's are different dizzy numbers!!
I heard these are good
http://cgi.ebay.com/ebaymotors...ZWDVW
Modified by alscrx at 2:11 PM 2/4/2008
Eric724
04-28-2011 06:23 PM
jakemuny
05-02-2010 06:30 AM
Corvair64
12-27-2009 02:10 PM
91rexhf
40
01-27-2009 09:45 PM
hondakevin21
06-14-2006 03:53 PM
Quick Reply: JDM b16 help
