i have clicking noise on the front right.passenger side
Old 07-25-2013, 10:01 PM
949's Avatar
Default i have clicking noise on the front right.passenger side
when i turn left i noticed some clicking noise. i dont know if something is loose or the bearing is out or if the cv is bad.
1991 civic wagon.
no noise when i accelerate, stop, right turns.
how should i test it unless you guys know what it might be.
my guess: cv joint or bearing. not sure how to even determine which one, or how to test it.
Old 07-25-2013, 10:37 PM
CO671's Avatar
Default Re: i have clicking noise on the front right.passenger side
Jack up car and do 3-9 horizontal test, and 6-12 vertical test.
3-9: Tie Rods inner/outer
6-12: wheel bearing
Check if there's play in the axle as I had the same problem before.
Old 07-26-2013, 06:10 AM
949's Avatar
thanks for the assistance.
im not familar with the horizontal and vertical test. can you elaborate.
im not folllowing what your trying to look for in the video. did you find what your testing for? is that the sound i need or not?
or are you looking for the looseness of the turns?
Old 07-26-2013, 03:37 PM
swordofdoom's Avatar
Do a turn with the steering wheel all the way to the right in a parking lot. If it clicks and clicks when your giving it gas its the CV going out. Repeat for the left .
Old 07-26-2013, 10:55 PM
CO671's Avatar
Lift the car off the ground so tires are in mid-air
Look at the face of the wheel/tire as a clock and on the 3/9 hour *Horizontal* and 6-12 hour *vertical*
the sound that I was hearing in parking lots, the clicking. So I went under the car and started spinning the axle to look for that sound, and it came from the inner CV joint. I just bought a new axle on Rockauto.com for like $40 shipped
Old 07-27-2013, 01:49 PM
949's Avatar
nice, thanks!
so there really is not point in getting oem again or even trying to repair the currect?
Old 07-27-2013, 04:28 PM
CO671's Avatar
OEM is almost always the best option, but if you can find a decent quality aftermarket (especially with a high mileage warranty thatd be great too) the most common purchased items on Rockauto have a heart next to it.)
Geoshanna
05-20-2013 07:27 AM
Secret Chimp
02-09-2008 01:27 PM
istabrak
05-11-2006 11:40 AM
AzCivic1.6
11-04-2005 05:53 PM
SIK IN DA HED
02-22-2003 03:59 PM
Quick Reply: i have clicking noise on the front right.passenger side
