how to change coolant temperature gauge
Re: how to change coolant temperature gauge
Are you sure the gauge is inoperable? Have you checked the circuit to the sensor and the sensor itself? Both are more likely to be the problem.
Coolant temp sensor is located on the left side of the block (facing the motor from outside the car) just under the distributor. I would test that first.
06sik20z3
08-08-2012 11:41 AM
stocker2shocker91
03-24-2008 01:19 PM
SPORT INJECTION
10-31-2004 10:36 PM
