anyone up late?? obd2 gsr in 89 dx hatch... all wired no spark!! what could it be??
is there something that enables spark of the dist. because i swapped distributors and it still wont start.. any help would be appreciated.. first ef build.. not familiar with this wiring.. please help!! ive called rywire and they never pick up or call me back... anyone got some places i can start troubleshooting??
Re: anyone up late?? obd2 gsr in 89 dx hatch... all wired no spark!! what could it be?? (raceready13
did you check for 12 V at the dist. (blk/yel).
if you do have 12 V, try disconnecting the oil pressure sensor
This may be a shot in the dark but have you checked the ecu fuse. Worth it to take a chance and check it.
thanks.. why disconnect that?? what does that do??
make sure the electrical is set up right... obd2 ecu, obd2 harness, obd2 distributor, obd2 o2 sensors... or obd1 if your doing that conversion.????
its just obd 2 injectors and dist. and i have a obd1 p28 chipped with obd0 to obd1 jumper...
maybe the injectors and the dist...? the distributor most likely.
raceready1320
01-23-2009 07:53 AM
