Help with Tach Install
Old 12-17-2006, 11:16 PM
ivan1985's Avatar
Default Help with Tach Install
I bought a 5 inch Autometer Phantom tach. Do I need to cut the looped blue, brown or both wires in the back? Thanks.
Old 12-18-2006, 04:13 PM
ivan1985's Avatar
Default Re: Help with Tach Install (ivan1985)
Can anybody give me an answer?
Old 12-18-2006, 04:17 PM
vw eater's Avatar
Old 12-18-2006, 04:23 PM
ivan1985's Avatar
Default Re: (vw eater)
Thanks but that does not answer my question. Nice try.
Old 12-18-2006, 04:24 PM
ludesrv's Avatar
It tells you how to install one, what else would u want?
Old 12-18-2006, 04:26 PM
zccr-xsi's Avatar
red= power
white= lightie cluster light fuse
black=ground
green=last one u can splice into the blue wire on the dizzy.
Old 12-18-2006, 04:27 PM
zccr-xsi's Avatar
the autometer paper tells u how to calibrate for a 4 cyl.
Old 12-18-2006, 05:43 PM
janz3n's Avatar
Default Re: (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">red= power
black=ground
green=last one u can splice into the blue wire on the dizzy.</TD></TR></TABLE>
that blue wires goes right to your cluster even if you dont have a rpm gauge, all wire harnesses are the same just that the clusters with no rpm dont have a pin for the blue wire. its easier to use it at the cluster then it is running a wire all the way to the distributor, and cleaner.
Old 12-18-2006, 06:55 PM
zccr-xsi's Avatar
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">
that blue wires goes right to your cluster even if you dont have a rpm gauge, all wire harnesses are the same just that the clusters with no rpm dont have a pin for the blue wire. its easier to use it at the cluster then it is running a wire all the way to the distributor, and cleaner.</TD></TR></TABLE>
true but i had to run it all they way there because i had short in my stock tach wire.
Old 12-18-2006, 10:22 PM
janz3n's Avatar
damn, that sucks, i hate shorts. just thought id let the guy know.. i know some people dont know that ever model has the tach wire.
Old 12-18-2006, 11:15 PM
ivan1985's Avatar
Yes I am aware of the instructions. Now, is an EF 2 pulse or 1 pulse? I have two looped wires in the back. Blue and brown. WHICH ONE DO I SNIP? BLUE, BROWN, OR BOTH?
Old 12-19-2006, 03:31 AM
Usdmowns's Avatar
you leave them both uncut for a v8, you cut the brown for v6, and cut both for a 4 cyc.... there
DC_RaceR
09-08-2006 04:24 PM
boosted 95 coupe
08-09-2006 12:03 AM
4DRmafia
28
10-10-2005 07:58 PM
SHIFKU(EF9 HOPE FUL)
09-21-2005 08:02 AM
CHRIS 1.8
05-31-2003 05:52 PM
Quick Reply: Help with Tach Install
