no spark after replacing cracked dizzy cap
Old 01-18-2013, 02:34 PM
GPC91's Avatar
Default no spark after replacing cracked dizzy cap
ok i have already done the park test and all came with weak spark. car sputters and blips but thats it. i took the dizzy off the car when i switched it because it was dark and i wanted to look over the rest of the dizzy. my main question before i get a new ignition coil is if i accidently turned the little thing that goes into the block half a rotation would that make my dizzy timing 180 deg out? and could this cause my weak spark? if not i guess i will have to spend the money.
Old 01-18-2013, 02:42 PM
Former User's Avatar
Default Re: no spark after replacing cracked dizzy cap
It's not possible to install an OEM distributor 180-degrees out of phase. Or do you have an aftermarket distributor?
Old 01-19-2013, 03:33 AM
GPC91's Avatar
nope its stock. i was just curious since its an obd1 dizzy. and i have read threads saying you can use a non vtec dizzy but it is 180 out. and i was just curious if somehow i messed it up putting mine in and ended up like this. but i guess im stuck spending the money to get it fixed. thanks for the help
Old 01-19-2013, 05:40 AM
Are you saying that you are able and did install your OEM distributor 180-degrees out of phase?
Old 01-19-2013, 09:51 AM
GPC91's Avatar
no i was saying that a non vtec dizzy is 180 out of what you need for a vtec. and in my laps of thinking i thought maybe turning the end of my vtec dizzy 180 that maybe it was out 180. but now that i actually think i realize that its internal that the dizzy is 180 different. i was just curious to see if i could save my self a few $ from rebuilding my dizzy but now it seems like no other option ha.
Old 01-19-2013, 09:55 AM
Originally Posted by GPC91
no i was saying that a non vtec dizzy is 180 out of what you need for a vtec...I realize that its internal that the dizzy is 180 different.
If this^ is true, I just learned something new. I knew that there were incompatibilities for VTEC and non-VTEC, but I didn't know the specific reason.
Can somebody verify?
Old 01-19-2013, 10:47 AM
ryanevansoh's Avatar
The non-vtec and vtec dizzys are the same minus how the mount to the head. You would have to force it and it would be very hard to get it to go in 180 degrees out.
Old 01-19-2013, 03:37 PM
This makes much more sense to me. Can somebody verify?
Old 01-19-2013, 09:24 PM
GPC91's Avatar
http://civic-eg.com/viewtopic.php?p=223990 this one says they are the same besides legs
http://www.tamparacing.com/forums/ho...tec-dizzy.html
this like has a thing showing that internally the non vtec and vtec are 180 out in the 4th comment. and it has pictures showing what he i talking about
Old 01-19-2013, 09:30 PM
EfyourK's Avatar
Cant you just take off the rotor on the back of dizzy that goes into the head, slide the pin out flip the rotor 180 an reinstall. I had to do that on my 91 accord cause I didn't put it on the same way I took it off.... My car had spark but since it was 180 off it would spark on the exhaust side instead of the intake side stopping the pistons from going all the way to top an WOULD not allow the car to start.
Old 01-20-2013, 11:10 PM
GPC91's Avatar
ok well i found a 94 civic for parts. it gets spark and no fuel. and its rusted pretty bad in the 1/4s but i figure if i paying 75 for an ignition coil i might as well spend a little more and just get another whole car ha just adding to my little junkyard.... but anyways anyone have an opinion of if i need to do anything to the dizzy other than not having one of the bolts fit on my engine. (the car has a d15b7 in it so its the non vtec dizzy)
prelude_si
03-29-2011 09:41 PM
EsCo_EsCo
09-29-2008 08:25 AM
brokenojoke
03-20-2006 02:43 PM
kuckimonster2
09-08-2004 06:52 PM
Quick Reply: no spark after replacing cracked dizzy cap
