HELP! Oil in intake
Old 06-20-2011, 06:21 PM
Edwin909's Avatar
Default HELP! Oil in intake
Ok so I just about had with this damn oil in my intake ive gotten advice to change the pcv but i dont believe thats the culprit. I seem to be getting oil from the hose that connects to the valve cover and intake. I believe an oil catch can can fix this but ive been getting confused with people running lines to the back of the block and running a gutted pcv and i just dont understand anything. I was just wondering if i could run the hose from the valve cover to the catch can then another hose from the catch can to the intake?... and any recommendation on catch cans. Im getting quite a bit of oil in the intake and it smokes white at high rpms
any advise or help is apprecaited even lecturing me is fine, im here to learn
Old 06-20-2011, 07:39 PM
BiG ChOr!Zo's Avatar
Default Re: HELP! Oil in intake
follow advice and change the damn pcv...!!!
Old 06-20-2011, 10:57 PM
Edwin909's Avatar
Ok so if i change my PCV off which car would i get it from I have a 1st gen b16 head with b18a1 bottom end?..
Old 06-21-2011, 02:13 AM
Spug's Avatar
From what I see on Majestic Honda's site, the 99 Civic Si (B16A1) and the 90 CRX Si (D16A60) use the same PCV valve, so just get one for a 90-91 CRX Si
Old 06-21-2011, 03:15 AM
DO IT ON ALL FOURS
OneBadTurboCRV's Avatar
Thought they were all the same? If you want then get one for a B16A3 it's the same...
Old 06-21-2011, 10:53 AM
Edwin909's Avatar
Ok help gladly appreciated but I the leakage doesn't stop will a oil catch can help at all and where would the hoses be connecting to?..
Old 06-21-2011, 12:14 PM
DO IT ON ALL FOURS
That's a lot more detailed and requires removing the "factory catch-can" to do iit right... So just try it and see what happens - in the mean time search google for catch can installs they are all over the place.
Old 06-21-2011, 03:22 PM
Edwin909's Avatar
Well i have searched but i just get confused for instance im sure the factory catch can your speaking of is the breather box i see on the back of the block?...... and can i just put a filter on the valve cover nipple and just block of the nipple on the intake?... ive seen people do that
Old 06-21-2011, 03:26 PM
Touching My Member
.Manny.'s Avatar
Your engine is probably not in great shape if its spewing that much oil. For simplicity, run the hose from your valve cover to a can, then from the can back into the intake. Done and done.
Old 06-21-2011, 06:49 PM
DO IT ON ALL FOURS
You could do that, but it will most likely drip oil down the back side of the engine. Yes, the breather box you speak of functions a lot like a catch can. Some people reroute the hose to the box but it typically creates more of a problem due to the engine not being able to vent. If you didn't want to fuss with taking out the box then run the catch can as high as possible and use the black box as a run off.
Catch cans typically have 3 ports. Some are return style others are containment that you have to manually drain perodicly. These in my opinion are a waste of time, not only that but you lose oil on top of it because it is not returning. The ports are - incoming from valve cover, vent to atmosphere, and drain/ return. Essentially you could make it out of a coffee can if you wanted to be ghetto.
To do it right remove the black box and seal the port and use the smaller port on on the block; or fab something to hook the return line through the factory drain back. Cap/ plug the other lines you removed besides the valve cover. Keep the catch can as high as physically possible. Run your lines to their respective places. That's all there is to it.
Old 06-21-2011, 09:04 PM
Edwin909's Avatar
You make it sound easy but im hella confused lol I know if you install a oil catch can properly you have better performance results but im just trying to prevent oil in my intake so after i replace the pcv which should be tomorrow i was wondering if i could just get an nrg catch can and connect to the valve cover and intake and if so will i need to put steel wool inside?....
jrdnwheeler
09-03-2008 08:48 AM
danteisme
10-22-2007 07:14 PM
Shaguar47
08-31-2007 03:30 PM
thomas188
10-07-2006 05:28 PM
94civicexlsvtec
04-11-2003 03:57 AM
Quick Reply: HELP! Oil in intake
