getting a higher compression ratio (b18a1)
Old 04-01-2010, 06:37 AM
gregRULES's Avatar
Default getting a higher compression ratio (b18a1)
i have an 89 crx dx with an ls swap, i believe the stock compression ratio in a b18a1 is 9.2-1. i am new to cars and was wondering how i would go about getting the ratio in the 11's...what parts would i need? and what kind of work would this entail? thanks in advance!
Old 04-01-2010, 07:26 AM
gregRULES's Avatar
Default Re: getting a higher compression ratio (b18a1)
bump, please helpppp! =]
Old 04-01-2010, 07:30 AM
JOE BD-0's Avatar
You can shave the head or use a thinner head gasket. Good luck.
Old 04-01-2010, 07:32 AM
Crazy Honda Guy
Deetz's Avatar
The best way to raise compression is a new set of pistons
Old 04-01-2010, 02:24 PM
blazzer's Avatar
remeber though when rasing your compression you need to think about octane levels(fuel) and a few other variations. if your new to cars or at least upgrading them do some resarch on on what you wanna do its not as easy as a simple piston swap if you are wanting 11:1 comp. ratio
Old 04-01-2010, 02:31 PM
beansandrice's Avatar
PR3 pistons and a P72 head.
Old 04-01-2010, 07:19 PM
Pirate General...YARRRR
Ass$nyper's Avatar
Good work
Old 04-01-2010, 09:10 PM
1RMDave's Avatar
Actually it is pretty much that easy. pr3 (b16) pistons will get him where he wants to be. Ran a b18a with i/h/e and pr3 pistons, it was much faster than my b16 swap. Ran 14.4 @ 94mph all day long on street tires.
Old 04-10-2010, 06:25 PM
blazzer's Avatar
hahahaha lol um NO its not
sure i/h/e help but it not that simple especially to the fact if your doing it "right" not some rednecked ghetto rigged job
swapping pistons to create a higher compression takes work, once that is done a new octane fuel is needed so that you do not casue detenation in your engine. once that is figured out you need a tune so your setup can run what octan level you wanna run or need to run thus that requires chipping you ecu.
you also need to think about spark plugs as a higher compression mean higher octane means higher heat levels thus resulting in the need for diffrent plugs.
swapping pistons in to a car and leaving it at that... NO, its not as simple as that period
if you think it is go ahead and do it that way fact is your garunteed to run in to issues very quickly. but dont just go off what im saying go do your research, gain some knowledge :D
skippy33
02-07-2021 05:34 PM
d.n.d.
07-17-2005 08:39 AM
CALM_AS_A_BOMB
03-14-2005 05:34 AM
CRneXt
09-27-2003 07:56 AM
aut0tek
03-18-2003 11:00 AM
Quick Reply: getting a higher compression ratio (b18a1)
