EDM spoiler need help...
Old 05-01-2008, 12:21 PM
jayden1295's Avatar
Default EDM spoiler need help...
Can any one guide me or help on how to put an edm spoiler on a usdm crx thanks ht...
Old 05-01-2008, 09:51 PM
jayden1295's Avatar
Default Re: EDM spoiler need help... (jayden1295)
anyone... pls
Old 05-01-2008, 10:03 PM
rexie's Avatar
I KNOW THIS IS GONNA MAKE ME SOUND REALY DUM BUT I DONT KNOW ALL THE TECHNICAL NAMES FOR EVERY THING COULD U BE A LITTLE MORE CLEAR ABOUT IT
Old 05-01-2008, 10:39 PM
jayden1295's Avatar
Default Re: EDM spoiler need help... (rexie)
EDM CRX siR 1.6i 16v Deck Spoiler!
https://honda-tech.com/zerothread?id=2112895
thanxx
Old 05-01-2008, 10:48 PM
zccrx's Avatar
first off is it original, if it is it should have studs sticking out from the bottom. when i did mine this is how i did it. get masking tape and lay it across the back end of the hatch. put dabs of grease so that when u place the spoiler it leaves a mark. drill the holes out, now a real spoiler is going to have some play on each stud that comes out of the spoiler, (in other words there is room for small error) you will have to remove the inside plastic panel. cant tell u if the wiper motor is in the way b/c i had taken mine out and shaved from the hatch. put down some rtv (black silicone sealant) on the outside then the spoiler in place and put on the small nuts from the inside. pretty simple my buddy and i did it with no prior experience. looks great too!! good luck
hope thats clear and helpful
Old 05-02-2008, 12:33 AM
jayden1295's Avatar
Default Re: EDM spoiler need help... (zccrx)
thanks zccrx i think its original dunno but how can you tell, i got mine from ebay straight from Germany... by the way thanks anyways... i will try this method
bobjohnson's Avatar
Yep, zccrx is right if its original, but if it doesnt have studs, and you dont want to put studs in the wing or drill into your car, you can buy some automotive double sided tape and stick it on there. As long as your hatch and the wing are completely clean there should be no adhesion issues, itll stick on there forever. If you ever want to get it off, just heat it up and pull, or worse comes to worse use a little bit of goo gone and a plastic paint scraper.
mardi
07-11-2018 06:39 PM
Cuong-nutz
17
12-24-2004 09:21 PM
Quick Reply: EDM spoiler need help...
