ECU chip help
ECU chip help
WE WANT TO CHIP OUR PM5 ECU OUT OF A 88-91 CRX DX AMD CANT FIND THE CHIP WOULD A PM6 ECU CHIP FOR A MULTIPORT WORK? THEY ARE AIR FUEL CHIPS TO ELIMINATE THE REV LIMITER
Re: ECU chip help (mreasyme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mreasyme »</TD></TR><TR><TD CLASS="quote">WE WANT TO CHIP OUR PM5 ECU OUT OF A 88-91 CRX DX AMD CANT FIND THE CHIP WOULD A PM6 ECU CHIP FOR A MULTIPORT WORK? THEY ARE AIR FUEL CHIPS TO ELIMINATE THE REV LIMITER</TD></TR></TABLE>
Why not just spend the $40.00 or so for an Si ECU and not waste money on some cheap crappy chip that will do more damage than good?
WE RACE OVAL TRACK AND NEED SOME MORE REVS BUT WOULD A SI WORK WITHOUT THE MULTIPORT INTAKE WE ARE ONLY ALOUD TO RUN DUAL POINT
Re: ECU chip help (Allday07)
They try to keep the tech easy and keep it up to the driver, But with that said would the si ecu work with the pm5 engine setup
Re: ECU chip help (sanimalp)
here it is DPFI sucks and you can use a MPFI ecu on it. I have seen bigger inj thrown on a DPFI setup with crappy results though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mreasyme »</TD></TR><TR><TD CLASS="quote">WE RACE OVAL TRACK AND NEED SOME MORE REVS BUT WOULD A SI WORK WITHOUT THE MULTIPORT INTAKE WE ARE ONLY ALOUD TO RUN DUAL POINT</TD></TR></TABLE>
Btw, where are you running?
alfaaay
04-07-2004 12:20 AM
