5th gear died while driving
Old 02-06-2012, 07:03 AM
SkiLLzWheeLz's Avatar
Icon2 5th gear died while driving
Was cruising home earlier down the highway about 70mph and 5th gear just went out. The shifter stayed in place but the tranny basically went into neutral. I didnt hear any noises or anything. Had to drive it home in 4th and had no more luck with fifth on a few extra tries. Transmission has always shifted perfect with no grinds and I drive it easy.
91 Civic Sedan DX w/ D15b vtec
Any ideas?
Old 02-06-2012, 07:35 AM
90civic-ZC's Avatar
Default Re: 5th gear died while driving
shifting linkages loose?
Old 02-06-2012, 07:54 AM
No everything is tight. The other gears work fine.
Old 02-06-2012, 08:02 AM
killerken25's Avatar
if you put the car in 5th and let off the clutch does it stall out?
Old 02-06-2012, 09:32 AM
No it doesnt stall.....just acts as if its in neutral. The shifter goes all the way forward like its supposed to. All other gears work.
Old 02-06-2012, 10:17 AM
PHANTOM MENACE
24TEN's Avatar
My guess would be the shift fork or something related specifically to it. 5th gear has it's own separate shift fork.
Old 02-06-2012, 11:27 AM
Could that go bad while driving in gear? I never grind the gears.....that requires tranny removal right?
d16efsedan
16
11-29-2016 09:35 PM
si_ek
05-22-2008 07:43 AM
eric416
06-23-2006 02:10 PM
vc
12-22-2005 06:58 PM
Rod.
11-11-2004 09:05 PM
Quick Reply: 5th gear died while driving
