crx wont stay running
I have a d15 dual point in my crx... it kept throwing a code for the tps... instead of just changing out the tps i put another throttle body that i know the tps was good on... when I did this the car had a little stutter on it... the top fuel injector was cracked so I took the old fuel injector off my other throttle body and put it in the one that is on it now... now the car will not crank unless I hold the gas pedal to the floor... when i do this it will barely crank and I have to keep mashing the gas to keep it going... Its blowing out fuel smoke and stuttering real bad... I tried changing out the spark plugs and new wires (which are getting spark) and changed out the fuel filter and the regulator... I dropped the gas tank and the fuel pump looks clean... I also changed out the computer with another one but still runs the same.... Im not getting any codes or anything either... I tried using the fuel system cleaner and the injectors are also spraying... when trying to crank it with starting fulid it will not crank... kinda makes me feel like im getting to much fuel but im not sure... someone please help, diesel is killing me and this is my daily driver...
santacruzccs
04-14-2011 08:34 AM
Dan-Dillinger
04-21-2006 11:26 AM
