Clunking noise when making hard turns
Old 02-07-2010, 07:20 PM
BrayzieEF9's Avatar
Default Clunking noise when making hard turns
so my problem is when I'm driving there's vibration and when i make hard turns there's a clunking noise replaced both my axles eliminated the vibration.but i still get the clunking noises when i make hard turns.what could it be??
Old 02-07-2010, 07:22 PM
Radim's Avatar
Default Re: Clunking noise when making hard turns
Are the Boots ripped?
Old 02-07-2010, 07:26 PM
JUNHONDAPOWER's Avatar
make sure the hold down bolts on your steering rack are tight. That will cause a clunk
Old 02-07-2010, 07:29 PM
BrayzieEF9's Avatar
alright i'll check my steering rack sometime tomorrow since its dark and i don't have a garage and my axles are new.
Old 02-07-2010, 07:30 PM
projekt90ef's Avatar
maybe its your cv joints...is it a clicking? or just clunking?
Old 02-07-2010, 07:41 PM
BrayzieEF9's Avatar
there's nothing wrong with my cv joints i just replaced them yesterday.its just a clunking noise when i make hard turns it feels like the wheel is gonna come off
Old 02-07-2010, 07:59 PM
stenger's Avatar
check your wheel bearings as well.
Old 02-07-2010, 08:07 PM
BrayzieEF9's Avatar
wouldn't my wheel bearings make noise if i was just driving straight?
Old 02-07-2010, 08:11 PM
stenger's Avatar
if they've gotten that bad yes.
Also it just hit me, I had this problem on a previous car. Check your end links on the sway bar, and the bushings.
Old 02-07-2010, 08:15 PM
BrayzieEF9's Avatar
i did when i replaced my axles they seemed fine
Old 02-07-2010, 08:19 PM
grog's Avatar
yeah it would make a noise, but turning can accentuate the noise (with a bad wheel bearing). but i doubt thats your problem.
I assume the noise is comming from the front, is that right?
is your car "slammed"? camber kit? whats your setup?
chech all of your bushings up front, dont forget to check the sway bar bushings.
Old 02-07-2010, 08:23 PM
BrayzieEF9's Avatar
skunk2 coilovers/struts skunk2 UCA camber kit not slammed and yes its coming from the front it feels like the wheel is gonna come off
Old 02-07-2010, 08:41 PM
grog's Avatar
Check your ball joints.
Camber kits can hit part of the frame if the car is low enough, but you would notice this because it would feel like bottoming out.
Old 02-07-2010, 08:45 PM
BrayzieEF9's Avatar
already checked it and i already had dat happened to me when i was rollin slammed and thats a completely different noise than what im hearing now.its like a clunking noise when your wheel ain't on properly.buh only when i make hard turns
Old 02-07-2010, 08:48 PM
stenger's Avatar
are your axles fully seated in the tranny? doesn't hurt to double check EVERYTHING tomorrow.
Old 02-07-2010, 08:52 PM
BrayzieEF9's Avatar
yuhp my axles are fully seated made sure when me and my homeboy put everything back together
Old 02-07-2010, 08:54 PM
BrayzieEF9's Avatar
oh yeah and the noise was happening before i put in the new axles.i had vibration while driving straight and clunking when i made hard turns.the new axles eliminated the vibration but i still get the clunking noise when i make hard turns
Old 02-07-2010, 09:04 PM
stenger's Avatar
Again, I'd go over the bushings, steering rack, stabilizer bar bushings, bar end links, wheel bearings. Could be something you just overlooked after the install. Tends to be something really dumb in my cases. lol
Old 02-07-2010, 09:09 PM
BrayzieEF9's Avatar
ye im gonna go over all that stuff tomorrow once i figure out what's goin on with my turn signals anybody know what would cause turn signals from signalling.like the lights work and everything just won't signal??
Old 02-08-2010, 08:22 AM
stenger's Avatar
Mine was just the fuse. I borrowed the high beam fuse to replace it, and haven't had an issue yet. My markes lit up, my hazards worked, but I had now individual signals.
If its not just the fuse, check the relay on it. The hazard relay should be the same, so just swap them around as a test.
Old 02-13-2010, 05:51 PM
BrayzieEF9's Avatar
alright so I went over my suspension today and turns out both my tie rod ends are blown LMAO!!!.can't believe I overlooked that when I was doing my axles,hahah man they are seriously ****ed up the boot looked like it was chewed up.time to order some new ones from the dealership.DISCOUNT FTW!!!
94 IntegraLS
09-30-2007 10:24 PM
Byaaah!
06-11-2007 07:26 PM
spender1326
05-31-2005 05:27 PM
AcCO12D95
08-28-2003 07:45 AM
DrunkenSailor
20
04-13-2002 10:20 PM
Quick Reply: Clunking noise when making hard turns
