checkengine-no code/no start
Old 04-20-2002, 12:04 PM
B pwr's Avatar
Default checkengine-no code/no start
anybody experience this.
Im helping my friend out, on his car(91 civic dx sedan d15b dualponit setup,) you turn the key to start the car, normally all the lights come on and go off, but the check engine stays on, doesnt throw any codes and they car will not start, he later toldme the car compartment was flooded with water, im thinking that ecus done.
Any body got ideas or solutions?
got a good battery, good alternator, put a good distrubitor cuz he originally told me it died while driving so i thought it was the igniter (nospark) from experince.
my car that happened once, checkengine stayed on, i clicked the key on and off till the light went off then the car would start but his is permanently on.
thanx
Old 04-20-2002, 12:06 PM
EP3_05's Avatar
Default Re: checkengine-no code/no start (crxpwr)
The ecu is definitely done. Just go out and see if you can get another one from a junkyard.
Old 04-20-2002, 03:10 PM
Urban Business
Guest
Posts: n/a
pm5 ecu? i have one if you need it $30+ s/h
[Modified by TorteX, 6:10 PM 4/20/2002]
Old 04-20-2002, 05:30 PM
flat-blk-HB's Avatar
check the ground on the thermostat housing!
Old 04-20-2002, 05:31 PM
Urban Business
Guest
Posts: n/a
Default Re: checkengine-no code/no start (89EF-BCUMBIE)
yep check grounds.
Old 04-20-2002, 05:48 PM
89 CRX SI's Avatar
Default Re: checkengine-no code/no start (TorteX)
funny stuff happens on hondas if your grounds arent on
Old 04-21-2002, 01:38 AM
RexB16's Avatar
Default Re: checkengine-no code/no start (89 CRX SI)
like they all said check grounds first, from there try a new ecu.
Old 04-21-2002, 05:55 AM
B pwr's Avatar
Default Re: checkengine-no code/no start (RexB16)
ok, thanx to all those that responded. i will do that check the grounds, i shouldve did that in the first place, then the ecu.
thanx
gnxpro24
Transmission & Drivetrain
04-21-2011 03:16 PM
ANONYMOUSdeecee
03-07-2007 07:47 PM
grneyez
13
01-06-2004 05:49 AM
hmonglonertim
08-10-2002 05:44 AM
Quick Reply: checkengine-no code/no start
