88 civic heater core?
Old 12-20-2004, 11:51 AM
ek4 coupe's Avatar
Default 88 civic heater core?
ok i did a search but still have a few questions. when the car is warm the hoses going into and coming out of the heater core are warm and the car is at the correct running temp. it isnt the thermostat cuz i put one in last year and it was the same before i did that.. but almost no heat is coming out of the blower. the fan works pretty good so its not that. also how much of the dash do you have to take apart to get at it..? any info would be great. thanks
Old 12-20-2004, 11:59 AM
DaX
DaX's Avatar
Heater core job = full dash removal as far as I know, my friend. Have you tried flushing your coolant system? Could be a clog in your core.
Old 12-20-2004, 01:15 PM
ek4 coupe's Avatar
Default Re: (DaX)
ya i flushed it when i changed the thermo... man i dont want to take out the full dash haha. damn it
Old 12-20-2004, 01:33 PM
Needs to be About 20% Cooler
DieMaster's Avatar
Default Re: (ek4 coupe)
just get a $30 electric hetter that plugs in the cigeret lighter
Old 12-20-2004, 02:12 PM
31flavorscivic's Avatar
Default Re: (DieMaster)
The valve may not be opening all the way on the heater core. Turn your car on and get it to normal operating temp. Have a friend take the little handle off of the control arm on the heater core and twist it slowly, while you sit inside the car and tell if the heat comes on. The arm could just be misadjusted.
Old 12-21-2004, 10:39 AM
ek4 coupe's Avatar
Default Re: (31flavorscivic)
no the little valve is opening all the way i did it by hand to check.. are there vents under the dash that let cold air in? i dunno im just trying to figure out all my options.. its probaly the heater core... atleast i hope it is since i just bought one hahah
2002hondaCivic
Honda Civic (2001 - 2005)
04-13-2018 03:50 AM
typeRaccord
03-05-2006 12:27 PM
Josue
10-21-2005 07:43 AM
Jet Black
15
12-12-2004 01:57 PM
Quick Reply: 88 civic heater core?
