brake booster hiss
Old 11-26-2006, 05:32 PM
supracrx's Avatar
Default brake booster hiss
i think my booster is going out because i hear a hiss everytime i depress the pedal...brakes still feel fine and i just changed front pads, rotors, rear shoes, and drums. i also hear a vacumn leak of some sort in the engine bay. when i shut the car off from insidem, u can hear air coming out and then stopping....is the booster bad or is there a seal that i can just change?
if its the booster how hard is it to remove it. cotter pin that holds the pedal? and 4 bolts to firewall all under dash, and just remove the MC? besides being a bitch to crawl under dash, is there any specific way of putting it back together? or do u just knock the cotter pin out and then the 4 bolts?
Old 11-26-2006, 10:45 PM
charlee's Avatar
Default Re: brake booster hiss (supracrx)
the best way is to remove your drivers seat and get under there and tackle that sucker. its really not that hard, and yes, you do have to remove the master cylinder to put it on the new brake booster.
Old 11-27-2006, 06:28 AM
hondaman86's Avatar
Make sure the hose going to the booster isn't leaking, if not than it is definitely your booster, it can be a pain working around the steering column.
Old 11-27-2006, 04:51 PM
Tyson's Avatar
could be a check valve. test your booster. couldnt be too hard to listen and pinpoint the source of the noise either i would think....
Old 11-27-2006, 05:52 PM
supracrx's Avatar
ok ill go do the checks...but if its the booster, does any other booster from another honda fit? i dont need performance, just something that is same as the stock SI for a 88 SI...with drum brakes in the rears. let m know
i know 89-91 CRX SI comes with disc brakes in the rear would that make a difference in booster?
i called parts store and they asked if the booster was a 7 inch diameter or 8 inch...is the SI ones 8 inch>?
Old 11-27-2006, 09:16 PM
supracrx's Avatar
ok booster is bad...i need to replace it....anyone know the difference in booster btwn the years? and if i get it at parts store is it the 7 inch diamter or 8 inch?
i might go ahead and just get a used one on ebay or here.....since a reman one is about $120 at the parts store...
Old 11-27-2006, 10:52 PM
MiX
MiX's Avatar
Default Re: (supracrx)
just to let u know there is a gasket in between the m/c and the booster, i thought my booster was bad also but was all leaking from the gasket.
Old 11-28-2006, 08:22 AM
Tyson's Avatar
http://www.norcalcrx.org/tyson/brakepartslist.xls
i would recommend just getting the same booster. theres no point in getting anything different.
Old 11-28-2006, 08:33 AM
supracrx's Avatar
well i did the booster test...after i shut the engine off pedal rises....so yea i think my booster is bad...and i can hear an audible hiss from under the dash
Old 11-28-2006, 08:44 AM
crawfo661's Avatar
i know a guy whos got a booster in a 90 dx hatch,i don't know if it will work, but if you think it will work hit me up for a price.
Old 11-29-2006, 01:04 AM
MiX
MiX's Avatar
change that gasket first before u do anyting u have to buy that gasket anyways change it first, i had the exact problem hiss sound.
Old 11-29-2006, 08:56 AM
supracrx's Avatar
which gasket are u talking about? is it from under the hood where the MC attaches to the booster or under the dash behind the pedal gaske? if u look at the san leandro honda catalog...all u see is the gasket under the dash?
Old 11-29-2006, 09:18 PM
supracrx's Avatar
anyone knoiw which gasket he is talking about?
Old 11-29-2006, 09:41 PM
eda6's Avatar
there's two gaskets..one between the booster and firewall. the other is between the bb and mc.
Old 11-29-2006, 09:54 PM
supracrx's Avatar
Default Re: (eda6)
is number 9 the seal or gasket to the firewall u guys are talking about?
i'm guessing that the #3 is the gasket to the booster and firewall under dash? correct?
if i'm wrong correct me..if its just the gasket i would rather do that...but i just can't find it on the website...or on partsamerica.com
Old 11-29-2006, 10:15 PM
goosane's Avatar
yeah, i just replaced one this past weekend in my ef, and a few years ago in my prelude. #9 is the little round gasket between the mc and the booster. make sure it's seated properly before you tighten the mc to the booster, if it's cocked up at all air will come out and the pushrod won't have any power behind it. #3 is the gasket between the booster and the firewall. it's nothing at all to worry about, it sits on the 4 studs so there's no real worry about getting it on straight. it's not really necessary to take out your seat to get in there, just move it back all the way and lay on your back on the floor. i got a booster and an mc at crazy ray's for about $30 total. i'm not sure if the crx and dx use the same booster, but the one out of a dx is 205v, so if your original crx one does too then it's ok i guess. hope that helped, good luck. oh yeah, USE FLARE WRENCHES FOR THE LINES! i can't stress that enough.
ps - this is what part of the alphabet would look like if q and r were eliminated
Old 11-29-2006, 10:35 PM
supracrx's Avatar
is crazy ray a local parts store or online?
yea i checked it out and i can get to it...just a pain but def capable....i just wanted to make sure its not the gasket.
so #3 i should just buy and see if thats whats causing the leak?
Old 11-30-2006, 05:30 PM
supracrx's Avatar
anyone know where to buy one of those gaskets btwn booster and MC?
Old 11-30-2006, 06:23 PM
goosane's Avatar
its a boneyard in md. i guess it wouldn't really apply to you since you're in ca. i guess you can look for a junkyard around there, because i don't think anyone would send their car to the junkyard because the brakes went out. so chances are the booster and mc are probably still good. try looking for one that was in an accident. if it doesn't work, you're only out 20 or 30 bucks at worst. clean it out really good though. if you buy a new or reman mc from an auto store they should give you a gasket with it. bleed bleed bleeeed those brakes when you're done with it.
Old 11-30-2006, 07:50 PM
FourthGenHatch's Avatar
Default Re: (goosane)
Why not take the time to upgrade now since you already have to spend the money. Get a 90-93 Integra Booster and MC (NON-ABS!!). MCs are like $30 reman. It's well worth the money for better brake feel and everything.
Old 11-30-2006, 08:08 PM
amthompson's Avatar
Default Re: (FourthGenHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">Why not take the time to upgrade now since you already have to spend the money. Get a 90-93 Integra Booster and MC (NON-ABS!!). MCs are like $30 reman. It's well worth the money for better brake feel and everything.</TD></TR></TABLE>
i think the integra mc requires bending of some lines and such
civic ex MC mounts right up and is 15/16
Old 11-30-2006, 10:29 PM
supracrx's Avatar
like i said i dont need to upgrade..this is my DD and i want this is as stock as i'm gonna pass it on to my sister soon...i just want to make sure everything is in good condition...that hiss is just getting me worried. i'll go buy another booster...for that seal btwn MC and booster...i have to get at honda or junkyard"?
Old 12-12-2006, 08:23 PM
supracrx's Avatar
thanks guys.....i put another booster i bought from ebay on and no more hiss
but just to let u guys know the gasket btwn the MC and booster was ripped...i used the one that came off the ebay one and no more leaks as of now THANKS GUYS
EFfin Sedan 91
07-30-2014 10:17 PM
The DX Rex
13
11-04-2013 05:06 AM
LSej1
04-29-2008 03:52 AM
mixmastabob
12-07-2006 12:09 PM
MNCRXSi
11-01-2006 06:49 PM
Quick Reply: brake booster hiss
