THE BEST THING TO USE TO PAINT VALVE COVER
Old 05-04-2004, 05:45 PM
jsteezy1290's Avatar
Default THE BEST THING TO USE TO PAINT VALVE COVER
i bought my b16 and im satisfied but the valve cover is shitty looking im wondering what kinda of paint and the procedures to paint it red
Old 05-04-2004, 05:58 PM
DC 2's Avatar
Default Re: THE BEST THING TO USE TO PAINT VALVE COVER (jsteezy1290)
powder coat it, spray paint will flake off. It you want it to look stock and you are going to spray paint it anyways look for wrinkle paint.
Old 05-04-2004, 06:14 PM
uneek4dr's Avatar
You can use engine enamel from wal mart. Supposed to be heat resistant up to 500 degrees. That and its made to put on the engine block. I am doing my valve cover right now.
Old 05-04-2004, 06:31 PM
bluecrxsi's Avatar
i used a spray on paint remover,cleaned it up well and used several light coats of engine paint. it loks great. i took my valve cover off when i did mine. piece of cake!
Old 05-04-2004, 08:25 PM
90civichbsi's Avatar
Default Re: (bluecrxsi)
just spray off the old crap with aircraft remover... then 500 degree paint is plenty for a valve cover. dont coat it on too thick, if you do it will crack.
Old 05-04-2004, 08:29 PM
5litereater's Avatar
Default Re: (90civichbsi)
500 dgree engine enamel + 500 degree clear coat = bling valve cover for less than 10 bucks.
Old 05-04-2004, 09:33 PM
Max_ED9's Avatar
Default Re: (5litereater)
where can flat red wrinkle paint be found? any stores or online somehwere?
Old 05-04-2004, 09:57 PM
junkyardRx's Avatar
Default Re: (Max_ED9)
summittracing.com
Old 05-05-2004, 08:54 AM
Default Re: (katsumoto)
wheres wrinkle paint at? can i sand the old **** off?
Old 05-05-2004, 09:24 AM
manson's Avatar
Default Re: (jsteezy1290)
call all the junk yards in your area...call JDM importers...make a post in th eclassifieds... buy a type r cover...best way to do it if you want red.
Old 05-05-2004, 09:58 AM
I3ackfire's Avatar
Default Re: (mansonclubpuir)
RICER
Old 05-05-2004, 10:35 AM
USDM 4G VTEC's Avatar
clean the valve cover with aircraft coating remover
then go to honda and buy the actual wrinkle paint
they sell it... ask acura also
paint it and be done.. ull have the real ****
Old 05-05-2004, 12:15 PM
Default Re: THE BEST THING TO USE TO PAINT VALVE COVER (USDM 4G VTEC)
what do you mean go to honda? a honda dealership?
Old 05-05-2004, 12:36 PM
SiRex91's Avatar
1.)Strip old paint off with Aircraft Remover
2.)Stand and clean the surface
3.)Mask off all areas that you don't want painted (oil cap hole, spark plug holes...)
4.)Use a high temp primer (Duplicolor, VHT, Plasticote) and give the valve cover a few coats of primer (I did 2 or 3 coats)
5.)Use a wrinkle paint (I used either Duplicolor or Plasticote, I can't remember) and apply as instructed on the can. For best results use a hair dryer or do it out in the hot sun to help wrinkle/cure the paint.
You can buy the paints at Pep Boys or Autozone. *Prepping the surface is the most important part of the process. If you do not spend a lot of time on this, the paint will crack, chip, or just plain turn out looking like **** if you do not do it properly (I learned that the hard way my first time).
I followed these steps and my valve cover turned out flawless. I don't have any pics that I can post b/c they are print film and I don't want to go to school to scan them.
Good Luck
Old 05-05-2004, 12:44 PM
Global Moderator
Jimmy's Avatar
Remove your valve cover and while your at it go ahead and buy a new valve cover seal.
Buy some aircraft remover or auto strip from ANY parts store for under $4.00
Spray air craft remover on the paint that you want off and get a tooth brush and scrub really hard and keep spraying and let it sit some also.
Then use some simple green to clean the greasy surface.
Next get you some 2000 grit sand paper and scuff the surface
<FONT COLOR="red">LAST BUT NOT LEAST</FONT>
Buy some VHT wrinkle paint from any parts store
Paint is available in red & black
Lay on thick coats and let it dry 5 minutes between coats for an excellent job.
***ALSO
<FONT COLOR="red">Search is key</FONT>
https://honda-tech.com/zerothread?id=779099
https://honda-tech.com/zerothread?id=774161
https://honda-tech.com/zerothread?id=716587
https://honda-tech.com/zerothread?id=655548
https://honda-tech.com/zerothread?id=664019
https://honda-tech.com/zerothread?id=669060
https://honda-tech.com/zerothread?id=664020
https://honda-tech.com/zerothread?id=650460
https://honda-tech.com/zerothread?id=630537
https://honda-tech.com/zerothread?id=602625
https://honda-tech.com/zerothread?id=567677
https://honda-tech.com/zerothread?id=451968
Old 05-06-2004, 11:28 AM
Default Re: THE BEST THING TO USE TO PAINT VALVE COVER (Usdmdc2)
another thing how the heck you tape the vtech and dohc letters up it looks impossible
Old 05-10-2004, 10:19 AM
manson's Avatar
you can sand off the paint from the raised letters.
if you tape it you can just lay tape over and exact-o knife the excess off.
Old 05-10-2004, 10:58 AM
CRXDrew's Avatar
Use vasoline for the letters. Just wipe it off. when everything is dry.
Old 05-12-2004, 08:59 PM
CaptivaBlue's Avatar
Default Re: (CRXDrew)
What color is a B16A valve color under the paint, I was under the impression it's just metallic lookin'. After taking the black powdercoat paint off my CBR rim's to reveal the silver shine I was thinkin' of doing the same to the B16A valve cover, go for the natural look, can I leave it unpainted, maybe clearcoat for protection, do B16s run any hotter than D16s? Does paint act as any sort of insulator? My D16 currently in the car, weeks away from swap, has an upainted valve cover and it has no ill effects on the hood's paint.
-=ZAK=-
01-15-2009 07:42 PM
xxxmikenicexxx
04-30-2005 11:14 AM
mountaindewguy
03-09-2005 06:37 PM
SmokyMtnRex
03-23-2002 09:21 AM
Quick Reply: THE BEST THING TO USE TO PAINT VALVE COVER
