BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (91 Civic)
Old 10-04-2005, 06:58 AM
Nisif's Avatar
Default BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (91 Civic)
So occasionally, when I drive my 91 Hatch the Seatbelt Dinger thing that makes the annoying beeping sound won't turn off even when I have my seatbelt on. In addition, the driver's side seatbelt light above the rearview mirror continues to blink as well. Have any of you disabled the "dinger" or have had this problem. It's by far one of the most annoying sounds to hear repeatively over and over again.
Old 10-04-2005, 07:06 AM
TheBobFather's Avatar
Default Re: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (Nisif)
look for it and stab it with a spoon kidding, i think it is something you can just pull, i forget
Old 10-04-2005, 07:15 AM
CRXB16T's Avatar
Try unplugging the wires to it located under the seat.
Old 10-04-2005, 07:22 AM
d357r0y's Avatar
Check your door jambs. Near where the door latch catches, there should be a little black "L" shaped piece of plastic mounted on a stainless steel bracket/slider. See if it's broken, it's an easy (less than 5 minute) fix.
If it is, you can do a couple things:
1. tape it back so it trips the switch and the door "seems" closed.
2. get another switch from the junk yard and replace it -2 phillips head screws and a slide on connector for the wires.
Old 10-04-2005, 07:35 AM
Nisif's Avatar
Default Re: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (CRXB16T)
Okay, didn't know that there was a plug underneath the seat, I know my DA has one but that is for the automatic seatbelts. I don't think the L-shaped door pin switch will matter though, because with the door closed it pushes on the switch. The typical problems with the door pin switches is that they don't move back when you open the door (had this problem when my interior light wouldn't come on, because the switch was stuck)
Old 10-04-2005, 07:39 AM
Nisif's Avatar
Update: I just went out to the car, found the plug that attaches to the seat pan (underneath the seat) and disconnected it, quick easy solution. No more idiot reminders or annoying beeps.
Old 10-04-2005, 07:40 AM
knew it was something you had to pull
Old 10-04-2005, 10:40 AM
Twilight's Avatar
Default Re: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (jnbhonda)
Good that you managed to get it off.
BUT, always use your seatbelts. They arent there for nothing.
Old 10-04-2005, 12:07 PM
Slow as piss's Avatar
im happy i ran across this post b/c the same thing happened to me this morning.... talk about irritating noises.
Old 10-04-2005, 12:50 PM
or at least i was happy.
after going outside to take a look under my seat, i realized that both the driver side and passenger side plugs have both already been disconnected.
but this morning it still beeped like crazy. is that possible?
Old 10-04-2005, 01:10 PM
Mr.Quang's Avatar
Default Re: (Slow as ****)
If you have a seatbelt light on your rear veiw mirror, take it off and unplug the blue plug.
Old 11-04-2005, 11:13 PM
Nisif's Avatar
Default Re: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (Twilight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twilight &raquo;</TD></TR><TR><TD CLASS="quote">Good that you managed to get it off.
BUT, always use your seatbelts. They arent there for nothing.</TD></TR></TABLE>
TICKET or CLICK IT...Familar Ohio Marketing Scheme for Buckling Up I do my best to avoid any tickets...yet 8 points on my license and hopefully not counting...
Old 11-05-2005, 01:02 AM
EFnerd's Avatar
i found my beeping in my crx on the indicator by the reveiw mirror and ripped it and out threw it on the ground and stabbed it with a phillips screwdriver....god i hated that thing after it stuck on.....
Old 11-14-2005, 04:24 PM
STDClayton's Avatar
Default Re: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (crxnerd)
expletive, i'm glad i found this post. my 91 dx hatch just started doing that.
Old 05-03-2016, 04:33 PM
sincereda9's Avatar
Default Re: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (91 Civic)
i have a 91 teggy hatch i just put nrg bucket seats and the beeping will not stop being that the bucket seats dont have the plugg under how do i stop the beeping on my da9
alwaystootall
09-21-2013 10:15 PM
morrowt21
01-07-2012 08:18 AM
jaysin04
11-22-2008 12:44 AM
dlszrfn
07-13-2005 08:44 AM
tominos
Audio / Security / Video
02-24-2004 07:13 PM
Quick Reply: BEEP BEEP. Help: Annoying Seatbelt Dinger Won't Turn Off (91 Civic)
