B18a1 Idle Issue!
Old 04-29-2011, 11:26 PM
88LsRex's Avatar
Icon2 B18a1 Idle Issue!
I can let my car warm up and it will go from 2k to about 1100rpms and stay there.
If I touch the throttle a little it will idle at about 1800rpms and stay there.
and if i drive it for about 5 minutes after i let it warm up it will idle at about 1800 and drop to about 1k then back to 1800rpms
So what could it be?
b18 is in my crx
Old 04-30-2011, 07:18 AM
ef_cowboy's Avatar
Default Re: B18a1 Idle Issue!
adjust your idle...screw on the tb...also check timing,tps voltage...i have the same problem when the seasons change i just adjust it and im good
Old 04-30-2011, 07:21 AM
alx_90ef's Avatar
are you using the proper throttle cable?
Old 04-30-2011, 07:37 AM
ef_cowboy's Avatar
if he wasnt then it would be stuck at 1800...ohh if you have that disk thing on your tb try unpluging that mine kepped my tb open all the time...
gabrielsousa
05-02-2014 07:53 AM
itzyaboyzeem03
09-30-2009 04:11 PM
emooheo
03-23-2007 02:34 PM
kaj
09-01-2004 04:37 PM
wantmorepower
08-21-2001 12:08 PM
Quick Reply: B18a1 Idle Issue!
