91 si stock cel resets itself please help
Old 01-13-2014, 08:09 AM
civicsiguy21's Avatar
Default 91 si stock cel resets itself please help
On my 91 si I get a random misfire while im driving and cel turns on if I shut the car off and turn it back on it turns off so I cant the code. What would make this happen? Ive changed the temp sensor, coil, icm, tps, wires, cap, rotor and plugs and still the same.
Old 01-13-2014, 08:47 AM
PHANTOM MENACE
24TEN's Avatar
Default Re: 91 si stock cel resets itself please help
You need to look at the ECU itself. The light on the gauge cluster just lets you know it was triggered. The light on the ECU will tell you if it's stored or not.
Old 01-13-2014, 09:57 AM
Keyboard Humorist
4drEF's Avatar
Well then don't turn the car off.
Leave the car on and jump the service connector to retrieve any code.
Old 01-13-2014, 01:03 PM
Just pulled back the carpet looking at the ecu soon as I turn the key to on position I get one flash a pause then 9 flashes
Old 01-13-2014, 01:19 PM
Keyboard Humorist
4drEF's Avatar
Oxygen sensor and a bad sensor in the distributor.
The 9 blink code makes sense of the misfire - that's the cyp sensor in the distributor.
The 1 blink for the oxygen sensor could actually be a false reading due to the misfire letting unburnt fuel past to the O2 sensor.
Old 01-13-2014, 01:45 PM
So if the cyp sensor is going bad should I just get a new distributor? Can I interchange it with any others? I have a stock d16a6 in the car with 196,000.
Old 01-13-2014, 02:34 PM
Keyboard Humorist
4drEF's Avatar
You should actually troubleshoot the CYP sensor first before replacing anything.
You can not readily repair any of the sensors in the distributor and will be better off getting a new one.
Old 01-13-2014, 02:45 PM
Except for the coil and icm which I have already changed. What besides a bad shaft bearing in the distributor trigger my cyp sensor?
90RENOsedan
12-21-2009 10:14 PM
sayiansean00
10-29-2006 05:00 AM
incognitoracerr
01-11-2004 07:13 PM
CRX SiR T
11-01-2003 08:26 AM
Eluzion
06-20-2003 12:08 PM
Quick Reply: 91 si stock cel resets itself please help
