90 HF radio harness issues..
Well i got a factory integra radio off a friend of mine and bought a factory integra harness (97 i believe..not to sure if it makes a difference) off another H-T member. I looked at the CRX PDF manual and got the color codes off of there but they dont match my harness in the crx for some reason and then i sourced the integra color codes from somewhere online and tried butting them up as best i could..to make this longer story short it didnt work and now im still stuck without a radio!
Does anyone have the diagram for a 90 HF? i was sure that it was the same for all 88-91 cars but i guess i can kick myself in the head for that one. I have the integra layout that that seems to be all correct (wire colors match the diagram)
or could someone tell me by color what wire does what? Thanks in advance..
Re: 90 HF radio harness issues.. (Slaughter)
Ive seen 2 different ones..
The one I have says
Ground - black
12v constant power - white/blue
12v switched power - white/green
Illumination - red/black
And another one I found online says
Ground - black
12v constant - white/blue
12v switched - yellow/red
The one I have says
Ground - black
Ground - black
go tohttp://www.installdr.com you will find all the wiring colors and where they go on each plug for each car
Re: 90 HF radio harness issues.. (d16efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16efhatch »</TD></TR><TR><TD CLASS="quote">go tohttp://www.installdr.com you will find all the wiring colors and where they go on each plug for each car </TD></TR></TABLE>
Thats where i picked up the integra diagram and the crx one i got that matched the one of the PDF manual.
ok then i also have this
12v switched power-white/green
12v constant power-white/blue
illumination/dimmer-red/black
ground-black
left front(+)-blue/green
left front(-)-green/black
right front(+)-red/green
right front(-)-brown/black
right rear(+)-red/yellow
right rear(-)-brown/white
left rear(+)-blue/yellow
left rear(-)-green/white
and the other one i have says the 12V Ignition wire is yellow/red so just play around with them you'll get it
ground-black
Thanks guys! since it's pretty late and im tired not to mention its dick freezing cold outside..im gonna check on it tomorrow. i guess i'll just have to drive the 4 door EF.
Aquafina
12-02-2007 06:18 PM
Slomo_civic
Audio / Security / Video
08-25-2006 08:26 AM
