1 and 2 air conditioner fan speed won't work.
the 1 and 2 option on the fan of the a/c won't work, I've heard this is a common problem on many civics of this gen. How can I fix it? a blown fuse?
3 and 4 work perfectly fine.
Re: 1 and 2 air conditioner fan speed won't work. (kuckimonster2)
Blown Resistors, actually. Easy fix. It is located behind the glove compartment. Simply order a new one and replace.
Its just called a resistor. You can go to honda and pick one up. Its this little plastic piece with a bunch of wires that determine the speed the blower goes. http://www.slhondaparts.com has it for about 22 bucks. you can probably pick it up at a dealership for like near 30. here is a link to a blow up of the piece.
http://www.slhondaparts.com/br...=true
Its number 5 in the picture.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuckimonster2 »</TD></TR><TR><TD CLASS="quote">What is a resistor? Is it the same as a fuse?
Sorry english is my second language.</TD></TR></TABLE>
The resistor simply drops the voltage down from 12 volts for the lower fan speeds.
hondcivic2003lx
Honda Civic (2001 - 2005)
09-28-2015 05:52 PM
