Y8 Cam vs. D16 cam
Old 05-14-2003, 12:58 PM
Risky Business
BauleyCivic's Avatar
Default Y8 Cam vs. D16 cam
EDIT Sorry for the title, its supposed to be Y8 cam vs. Z6 cam
How much more aggressive is the D16Y8 cam than the D16Z6 cam? I am doing a mini-me and i have access to both for free, although the Z6 cam is already in the head. Is it worth the time to rip apart the head and put in the Y8 cam, or just leave the Z6 cam in there?
Old 05-14-2003, 01:09 PM
luti's Avatar
Default Re: Y8 Cam vs. D16 cam (BauleyCivic)
I'm pretty sure they are basically the same, if anything the Y8 cam is slightly more aggressive. I can tell you that if you install a Z6 cam into a Y8 engine you need to advance it about 5 degrees for it to be at a relative zero location (valve timing is just slightly different between the 2).
Old 05-14-2003, 01:11 PM
piscorpio's Avatar
hmm, to probe further, if there is much difference in the two cams, which would be ideal for NA and which would be ideal for FI?
Old 05-14-2003, 02:32 PM
RyanEJ8's Avatar
The Y8 is a slightly more aggressive cam, might as well use that. Check this site out it has comparisons. It lists that Crower and Crane show different specs for the stock Y8 cam. Which one is correct???
http://www.hadamotorsport.com/D16camshafts.htm
boost and bass
11
04-13-2009 04:18 AM
bignosewhipper
06-01-2008 06:52 PM
Serdar
03-11-2006 06:43 AM
Hybrid
06-19-2003 09:37 AM
Quick Reply: Y8 Cam vs. D16 cam
