Wobbly front end under heavy acceleration???
Old 12-01-2005, 07:27 PM
Sean @ ESG's Avatar
Default Wobbly front end under heavy acceleration???
2000 civic si turbo:
Every time I get on the car pretty hard, it seems like the front wheels are gonna wobble right off the axles. The lugs are torqued correct and everything seems fine. But it didn't used to do this, and its pretty scary.
What could be causing this shaking?
Old 12-01-2005, 07:30 PM
bebfsu1's Avatar
Default Re: Wobbly front end under heavy acceleration??? (banzai msg)
It may be a bad wheel bearing. Jack up the front and see if the wheel wobbles when you try to move it.
Old 12-01-2005, 07:31 PM
Sean @ ESG's Avatar
Is it that easy to check for a bad wheel bearing? I can do that tomorrow and see. But I just had my wheels off and I didn't notice anything different.
Would it be a noticable movement?
Old 12-01-2005, 07:34 PM
RTFM
v4lu3s's Avatar
i would lean towards bad inner cv joints
Old 12-01-2005, 07:38 PM
StreetRacinThug's Avatar
Default Re: (v4lu3s)
I have the same problem maybe after 70 MPH and it started to shake pretty hard but I know i need an aligment and everyone is telling me that is the reason but also my car is so low that I need to lift the car before donig an aligment so maybe u should check if you car tugs to a side...
Old 12-01-2005, 08:04 PM
Sean @ ESG's Avatar
axles are brand new, and I thought it might be alignment too, but it doesnt happen when I accelerate a little. Only when I'm getting on it.
Old 12-01-2005, 11:30 PM
Sean @ ESG's Avatar
bump for answer
Old 12-01-2005, 11:31 PM
92ehatch's Avatar
Default Re: (banzai msg)
i had the same problem
i had the tires reblanced 10 times and it went away
Old 12-01-2005, 11:37 PM
burnitup's Avatar
did you check the ball joints. you might want to replace the suspion componts with aftermarket ones. the stock ones might not be able to handle the abuse as aposed to energy suspention bushings. just a thought. i mean how much extra power is there when you get on it now as compared to stock. idk
Old 12-01-2005, 11:39 PM
Sean @ ESG's Avatar
ive had this setup for about a year, the problem just recently started happening.
Old 12-01-2005, 11:54 PM
dohcVTECeg2's Avatar
rotors???
Old 12-02-2005, 12:21 AM
burnitup's Avatar
ok put the front wheels in the air lock the steering wheel and wigle the wheels from side to side to see if your ball joints are bad and or tie rod ends. when this happens does the steering wheel shimy if so how bad slite or really hard?
Old 12-02-2005, 12:35 AM
HT Order of Merit
JDM_Ej's Avatar
Default Re: (burnitup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnitup &raquo;</TD></TR><TR><TD CLASS="quote">ok put the front wheels in the air lock the steering wheel and wigle the wheels from side to side to see if your ball joints are bad and or tie rod ends. when this happens does the steering wheel shimy if so how bad slite or really hard?</TD></TR></TABLE>
If you have play at the rotor/hub, its your wheel bearing. Could be a tie rod as well. I would lean more towards the axles... I know you said they are new, but that don't mean ****. Did you get Autozone remans?
There is so much **** this could be... axles, tie rods, wheel bearings, warped rotors, sticking caliper, bad bushings, loose bolts. Welcome to the wonderful world of trial and error.
Old 12-02-2005, 08:37 AM
RTFM
v4lu3s's Avatar
when you say "brand new" axles do you mean brand new from honda? or remans from a parts store? i sometimes need to go back for axles 2 or 3 times before i get good ones.
Old 12-02-2005, 09:03 AM
Sean @ ESG's Avatar
the axles are NOT rebuilt. They are brand new. The rotors are fairly new Brembo's, and my driver side tie-rod is brand new from honda. I suppose it could be the wheel bearings, but what is the probability that both would go out at the same time.
I am the same guy that is having that clunking problem when I accelerate or depress/let off the clutch abrubtly. Could these two problems be related?
Old 12-02-2005, 09:29 AM
Mr. Badwrench
boostedcivicsir's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg &raquo;</TD></TR><TR><TD CLASS="quote">2000 civic si turbo:
What could be causing this shaking?</TD></TR></TABLE>
does the shaking go away when you are off of the throttle? if it does you have an inner cv joint going bad. it happened to my car on the dyno.
Old 12-02-2005, 12:29 PM
Sean @ ESG's Avatar
it does, but how can the inner cv joint go bad on an axle that has less than 100 miles on it
Old 12-02-2005, 12:36 PM
deadlock32's Avatar
http://www.evans-tuning.com/media.html
click on watkins glen and watch that movie... at the end you'll see how notice able a loose wheelbearing is = ]
Old 12-02-2005, 06:14 PM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banzai msg &raquo;</TD></TR><TR><TD CLASS="quote">it does, but how can the inner cv joint go bad on an axle that has less than 100 miles on it</TD></TR></TABLE>
inner joints fail with increased torque. it is a fact of nature. if they are stockers and you are making good power, it can happen.
wgbm92
05-21-2011 02:03 PM
lowtegsr
03-21-2009 03:50 PM
buzlink
16
10-18-2007 07:41 PM
PonoED
06-18-2007 12:19 PM
wu tang
13
01-03-2006 04:47 PM
Quick Reply: Wobbly front end under heavy acceleration???
