Wiring diagram for turbo timer
Re: Wiring diagram for turbo timer (RiceRocket12s)
in general, most turbo timers have five wires to worry about.
red, green, blue, black, grey
red - constant, connect to the big solid white wire
green, usually ignition, connect to the black w/ yellow
blue, usually accessory, connect to the solid yellow wire
black, ground, connect to ground
grey, usually parking brake circuit, run to ebrake wire and T into it
If you find that your engine turns off after wiring it up this way, swap your blue & green wires around. Make sure the parking brake is engaged (the brake light must be on).
EFLander
05-26-2010 03:50 PM
