wierd steering noise??
the noise is hard to describe kinda like a rubbing everytime the wheel spins if i go fast the noise gets faster slow it gets slower like rub rub rub faster slower coming from the front somewhere when i turn a little i can hear it more sometimes or when i accelerate and desellerate i can hear it better but if i hit the clutch it kinda goes away
Re: wierd steering noise??
does your steering look hard to turn or normal ?
i just had this issue 5 days back noise sound when i accelerate its increasing
first step remove you steering belt and start the car if its same noise its because of the idler pulley bearing .just buy an oem bearing remove the old one and install the new one be careful when you install it. it should fit with out losing balance
trying to see if anyone knows what this noise is it only happens when accelerating and deselerating.. sounds like somthing crunching around and around from the front
im not sure if it goes away when i push the clutch but its not as loud.. mostly accelerating/deselerating.. when i move the wheel the sound sometimes gets worse
The Grumpiest
I'm guessing that you didn't put the car on a lift like you claimed. How about actually getting under the car and looking instead of probing for magic answers?
