why would a front end bounce??
Old 03-22-2011, 05:41 AM
  #26
jmurphy's Avatar
Default Re: why would a front end bounce??
check your mounts, a front end bouncing could also be from bad cut springs or improper installment of spring/coil assembly
Old 03-22-2011, 05:48 AM
  #27
foo fighters's Avatar
Fourth post nailed it. Get new torque mounts,and maybe new motor mounts or inserts for them.good job 98civdx.
Old 03-22-2011, 06:01 AM
  #28
92cb7sk8er's Avatar
Originally Posted by grumblemarc
Bald tires and bouncing indicate you have a serious front end problem. Check all the bushings/balljoints-every part of the front end and get an alignment done. My wife's bounces on the drivers side and it's the tie-rods that need to be replaced. Considering you claim you've replaced these parts then it becomes less obvious what the problem is.
all that i have left to do is the alinement idk what else it could be everything else checks out other then the front sway bar is missing? but i dont think that would cause it.... the one on my accord is broken and it drives just fine ha
Old 03-22-2011, 06:02 AM
  #29
  #30
92cb7sk8er's Avatar
motor mounts would cause the car to bounce? O.o thats crazy ha
Old 03-22-2011, 06:04 AM
  #31
92cb7sk8er's Avatar
see i was thinking that to the last owner was a crack head and it does look like he did some work to the shocks but when i try to bounce the car when its parked they feel pritty strong...
  #32
The torque mounts will.Check your motor mounts and torque mounts for cracking and/or dry rot. Thats why they thought you couldn't drive 5spd.
Old 03-22-2011, 06:08 AM
  #33
92cb7sk8er's Avatar
The torque mounts will.check your motor mounts and torque mounts for cracking and/or dry rot.
i know the only bad motor mount is on the driver side the boot broke when we put the motor in idk if it will help but the bounce is on the passanger side? would that shortin the list of part to replace???
Old 03-22-2011, 06:17 AM
  #34
The bounce is on one side and not the other??? sounds like bent suspension components then(lower control arms,radius arms,upper control arms).Compare passenger side to drivers side to locate any bent stuff. Radius arms fixed??
Old 03-22-2011, 06:26 AM
  #35
NOYGDB's Avatar
Exactly the same thing im doing. But mine is the clutch. My rear main seals are leaking and its getting oil on the clutch which is causing hot spots on the the disc which is causing grabbing or chattering on the the clutch. I had this problem with my old hatch too and now my sedan is doing it. With almost 200,000 im not suprised at all.
In fact I thought it wold have been doing it earlier.
Old 03-22-2011, 06:33 AM
  #36
Nice! Worn out rear main seals,dry rotted torque mounts,bent radius arms... which is it ??Now you have to do the work and narrow down your options.let us know what it was when it's fixed.
Old 03-22-2011, 07:58 AM
  #37
92cb7sk8er's Avatar
alright will do
Old 03-31-2011, 12:52 PM
  #38
92cb7sk8er's Avatar
welll guys i fix it it was the alinment causing the bounce
Old 04-02-2011, 05:49 AM
  #39
just an alinement...amazing!!
Old 04-02-2011, 05:09 PM
  #40
92cb7sk8er's Avatar
lol thats what i was saying ha im so happy to have my car back though! thanks for everyones help!
javifunksEK
22
07-11-2012 03:45 PM
Sleeper91
02-08-2010 06:33 PM
Boner_Ben
05-26-2009 06:53 PM
tomato_man
04-17-2007 11:03 PM
boostin180sx
08-29-2004 12:18 AM
Quick Reply: why would a front end bounce??
