Why do starters go bad? Any guesses?
Old 08-30-2004, 08:24 PM
703_Sleeper's Avatar
Default Why do starters go bad? Any guesses?
I was just wondering why starters go bad. I understand parts get old and things malfunction. But is there some sort of prevention method that i can go about to ensure my starters longjevity? I just replaced my starter and i was wondering if maybe it was something i did. Probably not but what the heck maybe someone knows more than me. it's a 92 honda civic.
Old 08-30-2004, 08:47 PM
HitEm'Up's Avatar
Default Re: Why do starters go bad? Any guesses? (703_Sleeper)
The only thing you really can do to help a starters longeviy is do not start the car while its running!The drive or the solenoid usually go bad.
Old 08-30-2004, 08:50 PM
EK22snatch
Guest
Posts: n/a
Default Re: Why do starters go bad? Any guesses? (98turbohatch)
yeap. i see alot of solenoids go bad at my shop and theres nothing you can do about it. just one of those things you gotta replace after awhile
Old 08-31-2004, 09:49 AM
Default Re: Why do starters go bad? Any guesses? (EK22snatch)
kool, thanx guys!
Old 08-31-2004, 10:12 AM
Unceasing Measure
Archidictus's Avatar
Actually, wrapping your starter in a heat-resistant sleeve will help it last a long, long time. See, solenoids like the starter soilenoid are very prone to damage by heat and, since you can't get parts to rebuild a Honda starter (I've tried), the only way to help this to not happen is to prevent it with some kind of heat-resistance. If you have a long-tube header or turbocharger or exhaust leak, these things will all take life away from your starter. Wrap it up, plug the leaks and make sure the contacts are as clean as you can keep them and your starter should last for a long while.
BobbyRodriguez
11-25-2011 04:33 AM
mikehawkBUiLT
33
06-17-2007 03:37 AM
projectDrice
08-16-2006 01:08 PM
sexycivicgirl87
11
06-19-2006 10:01 PM
EGPHANTOM
02-26-2005 04:19 AM
Quick Reply: Why do starters go bad? Any guesses?
